查看: 3571|回复: 0
Makefile中.PHONY的浅析
发表于 2023-10-13 10:46:19 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Makefile中.PHONY的浅析
单词phony (即phoney)的意思是:伪造的,假的。来自collins的解释是:
If you describe something as phoney, you disapprove of it because it is false
rather than genuine.
那么,在Makefile中,.PHONY后面的target表示的也是一个伪造的target, 而不是真实存在的文件target,注意Makefile的target默认是文件。
举个例子:
  1. $ cat -n Makefile1
  2.      1    clean:
  3.      2        rm -f foo
  1. $ cat -n Makefile2
  2.      1    .PHONY: clean
  3.      2    clean:
  4.      3        rm -f foo
Makefile1和Makefile2的差别就是在Makefile2中定义了:
1 .PHONY: clean
直接Make看看
  1. $ ls -l
  2. total 8
  3. -rw-r--r-- 1 huanli huanli 18 Jul 13 17:51 Makefile1
  4. -rw-r--r-- 1 huanli huanli 32 Jul 13 17:51 Makefile2
  5. $ make -f Makefile1 clean
  6. rm -f foo
  7. $ make -f Makefile2 clean
  8. rm -f foo
Makefile1和Makefile2的行为没有啥子区别嘛,呵呵
创建一个文件clean, 再make看看
  1. $ touch clean
  2. $ ls -l
  3. total 8
  4. -rw-r--r-- 1 huanli huanli  0 Jul 13 18:06 clean
  5. -rw-r--r-- 1 huanli huanli 18 Jul 13 17:51 Makefile1
  6. -rw-r--r-- 1 huanli huanli 32 Jul 13 17:51 Makefile2
  7. $ make -f Makefile1 clean
  8. make: 'clean' is up to date.
  9. $ make -f Makefile2 clean
  10. rm -f foo
区别来了,Makefile1拒绝了执行clean, 因为文件clean存在。而Makefile2却不理会文件clean的存在,总是执行clean后面的规则。由此可见,.PHONY clean发挥了作用。
小结:
  1. .PHONY: clean
  2.     o means the word "clean" doesn't represent a file name in this Makefile;
  3.     o means the Makefile has nothing to do with a file called "clean"
  4.       in the same directory.
参考资料:
Phony Targets of GNU Make
GMT+8, 2026-4-18 14:56 , Processed in 0.146457 second(s), 39 queries .
