查看: 1075|回复: 0
CA51F551S3头文件
发表于 2025-5-29 21:44:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下是基于CA51F551S3芯片功能描述的头文件模板,包含关键外设的寄存器定义和配置选项。实际应用中需根据芯片数据手册调整寄存器地址和位定义:
cc复制c复制#ifndef __CA51F551S3_H
#define __CA51F551S3_H
#include <stdint.h>
// 系统时钟频率定义(需根据实际配置修改)
#define SYS_CLK_FREQ    16000000UL  // 默认16MHz高速RC振荡器
// GPIO引脚定义
typedef enum {
    GPIO_PORT0 = 0,
    GPIO_PORT1,
    GPIO_PORT2,
    GPIO_PORT3,
    GPIO_PORT_MAX
} GPIO_Port;
typedef enum {
    GPIO_PIN_0 = 0,
    GPIO_PIN_1,
    GPIO_PIN_2,
    GPIO_PIN_3,
    GPIO_PIN_4,
    GPIO_PIN_5,
    GPIO_PIN_6,
    GPIO_PIN_7,
    GPIO_PIN_MAX
} GPIO_Pin;
// GPIO模式定义
typedef enum {
    GPIO_MODE_INPUT   = 0x00,
    GPIO_MODE_OUTPUT  = 0x01,
    GPIO_MODE_PUSH_PULL = 0x02,
    GPIO_MODE_OPEN_DRAIN = 0x04,
    GPIO_MODE_ALT_FUNC = 0x08  // 复用功能模式
} GPIO_Mode;
// UART配置结构体
typedef struct {
    uint32_t baudRate;      // 波特率
    uint8_t  dataBits;      // 数据位(5/6/7/8)
    uint8_t  stopBits;      // 停止位(1/2)
    uint8_t  parity;        // 校验位(无/奇/偶)
    bool     rxEnable;      // 接收使能
    bool     txEnable;      // 发送使能
} UART_Config;
// I2C配置结构体
typedef struct {
    uint32_t clockSpeed;    // 时钟速度(标准/快速/高速模式)
    bool     addrMode10bit; // 10位地址模式
} I2C_Config;
// PWM通道配置
typedef enum {
    PWM_CHANNEL_0 = 0,
    PWM_CHANNEL_1,
    PWM_CHANNEL_2,
    PWM_CHANNEL_3,
    PWM_CHANNEL_4,
    PWM_CHANNEL_5,
    PWM_CHANNEL_MAX
} PWM_Channel;
// 系统复位源定义
typedef enum {
    RESET_SOURCE_POWER_ON   = 0x01,
    RESET_SOURCE_WATCHDOG   = 0x02,
    RESET_SOURCE_SOFTWARE   = 0x04,
    RESET_SOURCE_LVD        = 0x08,
    RESET_SOURCE_PIN        = 0x10
} Reset_Source;
// 关键寄存器地址定义(需根据实际手册调整)
#define REG_GPIO_PORT0_DIR    (*(volatile uint8_t *)0x8000)
#define REG_GPIO_PORT0_DAT    (*(volatile uint8_t *)0x8001)
#define REG_UART_CTRL         (*(volatile uint8_t *)0x9000)
#define REG_UART_BAUD         (*(volatile uint16_t *)0x9002)
#define REG_I2C_CTRL          (*(volatile uint8_t *)0xA000)
#define REG_PWM_CONFIG        (*(volatile uint8_t *)0xB000)
#define REG_SYS_RESET_CAUSE   (*(volatile uint8_t *)0xC000)
// 外设使能宏
#define UART_ENABLE()         (REG_UART_CTRL |= 0x01)
#define UART_DISABLE()        (REG_UART_CTRL &= ~0x01)
#define I2C_MASTER_MODE()     (REG_I2C_CTRL |= 0x02)
#define PWM_CHANNEL_ENABLE(ch) (REG_PWM_CONFIG |= (1 << (ch)))
// 中断相关定义
void UART_IRQHandler(void);
void I2C_IRQHandler(void);
void PWM_IRQHandler(void);
// 初始化函数声明
void System_Init(void);
void GPIO_Init(GPIO_Port port, GPIO_Pin pin, GPIO_Mode mode);
void UART_Init(const UART_Config *config);
void I2C_Init(const I2C_Config *config);
void PWM_Init(PWM_Channel ch, uint16_t period, uint16_t duty);
#endif // __CA51F551S3_H
关键点说明:
寄存器地址需要根据实际数据手册调整
支持的功能包括:
GPIO多模式配置(输入/输出/复用)
UART全参数配置
I2C主从模式支持
6通道PWM独立控制
系统复位源检测
提供基础的外设初始化函数框架
需配合对应的.c文件实现具体功能
中断服务例程需要用户根据需求实现
建议在实际使用时:
添加寄存器位的位域定义
补充完整的寄存器地址映射
实现外设初始化的具体逻辑
添加必要的错误检查机制
根据封装类型调整引脚定义
+15
GMT+8, 2026-5-24 03:17 , Processed in 0.593007 second(s), 37 queries .
