查看: 2967|回复: 0
RV1103开发环境搭建 基于 Luckfox Pico SDK编译
发表于 2023-12-7 10:09:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • 本SDK基于RK官方提供的SDK修改而来
  • 专为Luckfox Pico系列开发板提供客制化的SDK
  • 旨在为开发者提供更好的编程体验
SDK 介绍
  • 当前main分支,rootfs使用buildroot构建,可以更加轻松的添加或者删除应用程序
  • 原先使用busybox直接构建rootfs,被移动到busybox分支
默认应用
默认SDK中开启或者装有应用(包括但不限于)
  • python3
    • 默认开启以下库
    • PERIPHERY
    • PILLOW(暂时无法加载字体)
    • SERIAL
    • SMBUS
    • SPIDEV
  • ssh
    • 默认开机自启
    • 账号为root
    • 密码为luckfox
  • samba
    • 默认开机自启
    • 账号为root
    • 密码为luckfox
  • adb
    • 默认开机自启
SDK 使用说明
  • 推荐使用系统为Ubuntu 22.04
安装依赖sudo apt-get install repo git ssh make gcc gcc-multilib g++-multilib module-assistant expect g++ gawk texinfo libssl-dev bison flex fakeroot cmake unzip gperf autoconf device-tree-compiler libncurses5-dev pkg-config
获取SDKgit clone https://github.com/LuckfoxTECH/luckfox-pico.git
环境变量
  • 需要将交叉编译工具链设置
cd {SDK_PATH}/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/source env_install_toolchain.sh
build.sh使用说明
  • SDK使用build.sh脚本实现自动编译,大部分编译操作均可以通过build.sh自动完成.
build.sh全部可用选项Usage: build.sh [OPTIONS]Available options:lunch              -Select Board Configureenv                -build envmeta               -build meta (optional)uboot              -build ubootkernel             -build kernelrootfs             -build rootfsdriver             -build kernel's driverssysdrv             -build uboot, kernel, rootfsmedia              -build rockchip media librariesapp                -build apprecovery           -build recoverytool               -build toolupdateimg          -build update imageunpackimg          -unpack update imagefactory            -build factory imageall                -build uboot, kernel, rootfs, recovery imageallsave            -build all & firmware & saveclean              -clean allclean uboot        -clean ubootclean kernel       -clean kernelclean driver       -clean driverclean rootfs       -clean rootfsclean sysdrv       -clean uboot/kernel/rootfsclean media        -clean rockchip media librariesclean app          -clean appclean recovery     -clean recoveryfirmware           -pack all the image we need to boot up systemota                -pack update_ota.tarsave               -save images, patches, commands used to debugcheck              -check the environment of buildinginfo               -see the current board building information
选择参考的板级配置./build.sh lunch
将会输出对应的板级配置选项,输入对应板级配置的编号即可切换对应的板级配置
You're building on LinuxLunch menu...pick a combo:BoardConfig-*.mk naming rules:BoardConfig-"启动介质"-"电源方案"-"硬件版本"-"应用场景".mkBoardConfig-"boot medium"-"power solution"-"hardware version"-"applicaton".mk----------------------------------------------------------------1. BoardConfig_IPC/BoardConfig-EMMC-NONE-RV1103_Luckfox_Pico-IPC.mk                            boot medium(启动介质): EMMC                        power solution(电源方案): NONE                        hardware version(硬件版本): RV1103_Luckfox_Pico                            applicaton(应用场景): IPC--------------------------------------------------------------------------------------------------------------------------------2. BoardConfig_IPC/BoardConfig-EMMC-NONE-RV1103_Luckfox_Pico_Mini_A-IPC.mk                            boot medium(启动介质): EMMC                        power solution(电源方案): NONE                        hardware version(硬件版本): RV1103_Luckfox_Pico_Mini_A                            applicaton(应用场景): IPC--------------------------------------------------------------------------------------------------------------------------------3. BoardConfig_IPC/BoardConfig-SPI_NAND-NONE-RV1103_Luckfox_Pico_Mini_B-IPC.mk                            boot medium(启动介质): SPI_NAND                        power solution(电源方案): NONE                        hardware version(硬件版本): RV1103_Luckfox_Pico_Mini_B                            applicaton(应用场景): IPC--------------------------------------------------------------------------------------------------------------------------------4. BoardConfig_IPC/BoardConfig-SPI_NAND-NONE-RV1103_Luckfox_Pico_Plus-IPC.mk                            boot medium(启动介质): SPI_NAND                        power solution(电源方案): NONE                        hardware version(硬件版本): RV1103_Luckfox_Pico_Plus                            applicaton(应用场景): IPC--------------------------------------------------------------------------------------------------------------------------------5. BoardConfig_IPC/BoardConfig-SPI_NAND-NONE-RV1106_Luckfox_Pico_Pro_Max-IPC.mk                            boot medium(启动介质): SPI_NAND                        power solution(电源方案): NONE                        hardware version(硬件版本): RV1106_Luckfox_Pico_Pro_Max                            applicaton(应用场景): IPC----------------------------------------------------------------Which would you like? [0]:
输入对应的序号选择对应的参考板级。
一键自动编译./build.sh lunch   # 选择参考板级./build.sh         # 一键自动编译
单独编译U-Boot./build.sh clean uboot./build.sh uboot
生成镜像文件: output/image/MiniLoaderAll.bin output/image/uboot.img
单独编译kernel./build.sh clean kernel./build.sh kernel
生成镜像文件: output/image/boot.img
单独编译rootfs./build.sh clean rootfs./build.sh rootfs
  • 注:编译后需使用./build.sh firmware命令重新打包
单独编译media./build.sh clean media./build.sh media
生成文件的存放目录:
output/out/media_out
单独编译参考应用./build.sh clean app./build.sh app
  • 注1:app依赖media
  • 注2:编译后需使用./build.sh firmware命令重新打包
固件打包./build.sh firmware
生成文件的存放目录: output/image
注意事项在windows下复制源码包时,linux下的可执行文件可能变为非可执行文件,或者软连接失效导致无法编译使用。因此使用时请注意不要在windows下复制源代码包。
GMT+8, 2026-5-24 14:44 , Processed in 0.133819 second(s), 38 queries .
