查看: 4532|回复: 0
基于高通QCS610视觉智慧平台之智慧摄像头应用
发表于 2022-10-29 23:50:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
QCS610规格简介
       高通的人工智能 (AI) 引擎和异构计算架构中,专为边缘物联网应用设计,包括高达八核Qualcomm® Kryo™ 460 CPU、Qualcomm® Adreno™ 612 GPU 和 Qualcomm® Hexagon™ DSP 的组合,并搭配高通PM6150、PM6150L电源管理IC,实现低功耗、电源最佳化及高运算能力。
       影像显示方面,提供1x 4 lane DSI DPHY 1.2,最高2520x1080 60 fps和Display Port,r分辨率可达1920x1200 60 fps。另一方面在影像输入部分,采用高通Qualcomm Spectra™ 250L 影像处理器 (image signal processor, ISP),提供3组4 lane (or 4+4+2+1), DPHY1.2, CPHY 1.0,并支持时域降噪 (Temporal Noise Reduction, TNR)、交错的高动态范围 (Staggered High-Dynamic Range, sHDR)、电子式防手震 (Electronic Image Stabilization, EIS)、镜头畸变校正 (Lens Distortion Correction, LDC)等功能。
    至于IO界面有Ethernet RGMII、802.11a/b/g/n/ac、Bluetooth 5.0、SD3.0、USB3.1、USB2.0等标准,其规格简表如图1-1、表1-1:
表 1‑1 QCS610 规格表
QCS610
CPU
Kryo 460: 64-bit Octa-cores, 2x Gold (2.2GHz) + 6x Silver (1.8GHz)
GPU
Adreno 612 @ up to 845MHz ;
API Support: Vulkan® 1.1, OpenCL™, OpenGL® ES 3.2
Audio Playback
Hi-Res/192kHz, Native 44.1kHz, audio on dedicated DSP
Compute DSP
Hexagon DSP with 2 Hexagon Vector eXtensions (HVX), 1.1Ghz
Sensor DSP
Hexagon DSP based
Memory
2x 16-bit LPDDR4.x 1804MHz
PMIC
Qualcomm® PM6150 + Qualcomm® PM6150L
Display
Resolution
2520x1080 60 fps + 1920x1200 60 fps (External)
Interface
1x4 lane DSI DPHY 1.2 support + DP over USB-C (external)
Camera
Performance
Image Signal Processor: Qualcomm Spectra™ 250L image signal processor, 14-bit, 24MP (2x ISP/16+16MP),
4K30 IQ improvement: MCTF, TNR, sHDR, EIS, LDC, Dewarp, Zoom
Interface
CSI 4+4+4 lane (or 4+4+2+1), DPHY1.2, CPHY 1.0
Video
Decode
4K30 8-bit: H.265(HEVC)/VP9
Encode
4K30 8-bit HEVC
Location
GPS/GLONASS, BeiDou, Galileo
Wired/Wireless
Connectivity
Ethernet RGMII
Integrated 1x1 802.11a/b/g/n/ac and Bluetooth 5.0
FM
Storage
eMMC 5.1, UFS 2.1 Gear3 1-lane, SD 3.0
Peripherals
1x USB3.1 Type-C with Display Port and USB 2.0
Technology / Package
11nm, 12x11.1x0.92mm non-PoP
  • 名词翻译
TNR : Temporal Noise Reduction 时域降噪
sHDR : Staggered High-Dynamic Range 交错的高动态范围
EIS : Electronic Image Stabilization 电子式防手震
LDC : Lens Distortion Correction 镜头畸变校正
QCS610 SOM简介
    本单元专注在QCS610 SOM的介绍,内容浓缩高通多份技术文件,例如有关特性、引脚定义、机械和电气设备特性的信息,请参阅QCS610/QCS410设备规格DOC# 80-PL052-1。透过文件整理后,能让硬件技术人员在最短的时间, 透过此份内容, 初步了解高通各IC的相关性和一般pin脚功能定义组态,如I2C、SPI、UART….等。
    此外内容会尝试以图表型式来表达意义及相关性,而参考的文件会紧接着图表,方便读者能更深入地了解其前后文的意涵。其次编排顺序上,依次为SOM功能方块图、SOM PIN脚编排及名称、SOM IO规格及功能、电源与充电、无线通讯测试报告(BT + WiFi 2.5G/5G Hz)。
    但因有些内容无法在这说明,诸如SOM PIN脚编排及名称、SOM IO规格及功能、电源与充电,部分无线测试报告,若想取得详细资料,请洽诠鼎科技公司。
QCS610 SOM组成架构
    SOM功能由高通QC610主芯片、PM6150+PM6150L PMIC、无线通讯芯片WCN3980和eMCP (4GB LPDDR4X + 64GB eMMC)所组成,如2-1所示。
    首先,PM6150与PM6150L均为PMIC ( power management IC ) 针对QCS610 芯片组进行了电源管理优化,其中PM6150为主控部分,掌管系统电源开关、电池充放电、供给系统各部时钟及供应系统多组电压(refer to PM6150规格DOC# 80-PH856-1 Rev. K) ; 其搭配的PM6150L主要角色除了提供多组电源及一组Buck or Boost(BoB)电源,也提供LEDs驱动电源(refer to PM6150L规格DOC# 80-PG281-1 Rev. L) 。
    高通WCN3980为1X1, 2.4G/5G band 无线前端IC,与QCS610搭配后可支持WiFi 802.11a/b/g/n/ac and Bluetooth 5.0,使产品成为无线连网装置。
    最后,主芯片QCS610除了高效能、低功耗和硬件神经网络加速器外,亦提供多样化、多组数IO界面,如MIPI-CSI、MIPI-DSI、USB3.0、USB2.0、I2C、SPI、UART、I2S等,此外,广泛的GPIO脚PIN可以帮助设计者灵活的应用及布局PCB,减少绕线发生,降低EMI发生因素。
AIT QCS610 SOM Feature
QCS610 SOM
CPU
GPU
Compute DSP
Audio Playback
Sensor DSP
Hexagon DSP based
Memory
32Gb LPDDR4.x
64GB eMMC5.1
Wireless Connectivity
Bluetooth 5.0
PMIC
Display
Resolution
2520x1080 60 fps
Interface
Camera
Performance
4K30 IQ improvement: TNR, sHDR, EIS, LDC
Interface
Video
Decode
Encode
4K30 8-bit HEVC
SOM Size
40 mm x 45 mm
No.
IO name
Port
Description
1
802.11a/b/g/n/ac
Bluetooth 5.0
1
1x1 antenna
2
RGMII
1
One RGMII interface with MDIO for
Ethernet with AVB (1.8 V only for
RGMII and MDIO)
3
SPI
4
SPI interface – 4 on GPIO and 2 on
LPI for cameras, sensors, and so on;
dedicated controller for each port
4
UART
2
UART interface 4 on GPIO – 3 on
LPI island for sensors
5
I2C
4+2
>> I2C interface – 4(6) on GPIO and 1 on
LPI for touch, sensors, and so on;
>> Two dedicated I2C interfaces for camera
6
SD
1
4-bit SDC2 for SD Card 3.0
7
USB3.0
1
8
USB2.0
1
Option(Host)
9
CSI
3
2 ports 4 lanes ; 1 port 2 lanes
10
DSI
1
1 port 4 lanes
11
DMIC
2
12
GPIOs
20
13
I2S
2
1 is for WCD9370
硬件设计说明
线路图分成两部分 :
一为主核心线路 ;另一部分为周边应用(不在此次介绍),如图2-2,。
  • 主核心芯片框架图( QCS610+eMCP+PM6150+PM6150L+WCN3980 ) :
图 2‑1
  • 周边应用框架图(WCD9370 Audio CODEC+WSA8815 Audio AMP+LT9611 HDMI transmitter+KSZ9031RNXIA Gigabit Ethernet PHY):
图 2‑2
  • QCS610 SOM位置说明
PCB layout
  • AIT QCS610 SOM Dimension and Placement
  • PCB叠构 :
  • 阻抗控制表
QCS610无线通讯测试
    无线通讯测试方式是透过LITEPOINT的IQxel-MW设备针对WiFi-2G/5G频段及调变方式做整体测试,内容概括整体效能,诸如输出功率、频率偏差、EVM值等,也包含频谱遮罩和误差向量幅度星座图,如附图。
  • IQxel测试仪器架设图
  • IQxel 2.4G效能、频谱遮罩和误差向量幅度星座图
2.4G OFDM TX效能表
2.4G OFDM频谱遮罩
2.4G OFDM EVM星座图
  • IQxel 5G效能、频谱遮罩和误差向量幅度星座图
5G OFDM TX效能表
5G OFDM频谱遮罩
5G OFDM EVM星座图
Pre-scan EMI
    本单元测试分为两部分,如下图5-13红色框。一为针对无线通讯发射状态做接触式量测,目的在于检测主频旁的谐波(harmonic)及输出功率,一般在Conducted Emission (CE)阶段符合法规,则在辐射量测(Radiated Emission)也会符合法规。二为针对系统做辐射测试 (Radiated Emission, RE),此部分需在辐射暗室(Chamber)进行。
  • 电磁相容测试相关项目
Conducted Emission
    Conduction部分架设
  • 频谱分析仪架设图
  • 测试结果图
2.4G Power conduction
5G Power Conduction
Radiated Emission
       产品做EMI中的辐射传导测试时,需在暗室下进行,而大联大控股目前的暗室是7X4X3规格,搭配的测试设备如后续图显示。一般扫描测分为4部分,分别为1GHz以上的水平、垂直扫描和1GHz以下的水平、垂直扫描。此外,此次1GHz以上部分使用EN55022规范,而1GHz以下使用CISPR32规范。
暗室隔离度
大联大电波暗室图及测试设备
  • 测试环境图(Radiated Emission测试示意图)
1GHz以上-待测物位置
1GHz以下-待测物位置
  • 测试结果 :
1GHz以上水平扫描
1GHz以上垂直扫描
1GHz以下水平扫描
1GHz以下垂直扫描
可提供的文件列表
  • 应用主板的电路图( Version : OrCAD16.5 )
  • 10层PCB layout档 ( Version : PADS9.3 )
  • PCB 叠构
  • 使用的零件列表
  • 零件资料
以上资料均需透过业务/PM认可及完备手续
►场景应用图
►产品实体图
►展示板照片
►方案方块图
►核心技术优势
        AIT使用QCS610视觉智能平台,提供一total solution,帮助开发者缩短硬件开发期,使其能专注在软件应用,此外,高通在人工智能软件上,也提供辅助资源,有兴趣者可访高通SNPE ( Snapdragon Neural Processing Engine )网站: https://developer.qualcomm.com/s ... /snpe/overview.html .
►方案规格
AIT QCS610 SOM Feature:QCS610 SOM;CPU :Kryo 460: 64-bit Octa-cores, 2x Gold (2.2GHz) + 6x Silver (1.8GHz);GPU :Adreno 612 @ up to 845MHz ,API Support: Vulkan® 1.1, OpenCL™, OpenGL® ES 3.2;Compute DSP :Hexagon DSP with 2 Hexagon Vector eXtensions (HVX), 1.1Ghz;Audio Playback :Hi-Res/192kHz, Native 44.1kHz, audio on dedicated DSP;Sensor DSP :Hexagon DSP based;Memory :32Gb LPDDR4.x;64GB eMMC5.1;Wireless Connectivity :Integrated 1x1 802.11a/b/g/n/ac ,Bluetooth 5.0;PMIC :Qualcomm® PM6150 + Qualcomm® PM6150L;Display :Resolution 2520x1080 60 fps,Interface 1x4 lane DSI DPHY 1.2 support ;Camera :Performance 24MP (2x ISP/16+16MP), 4K30 IQ improvement: TNR, sHDR, EIS, LDC;Interface CSI 4+4+4 lane (or 4+4+2+1), DPHY1.2, CPHY 1.0;Video ecode 4K30 8-bit: H.265(HEVC)/VP9,Encode 4K30 8-bit HEVC;SOM Size :40 mm x 45 mm;===========================No. IO name                                                    Port                 Description1 .802.11a/b/g/n/ac and Bluetooth 5.0    1                      1x1 antenna 2 .RGMII                                                            1                One RGMII interface with MDIO for 3. SPI        4                SPI interface – 4 on GPIO and 2 on LPI for cameras, sensors, and so on; dedicated controller for each port4 .UART                                                            2                UART interface 4 on GPIO – 3 on LPI island for sensors5 .I2C                                                             4+2                >> I2C interface – 4(6) on GPIO and 1 on LPI for touch, sensors, and so on; dedicated controller for each port >> Two dedicated I2C interfaces for camera6 .SD        1               4-bit SDC2 for SD Card 3.07. USB3.0                                                        1  8. USB2.0                                                        1                Option(Host)9 .CSI                                                               3                2 ports 4 lanes ; 1 port 2 lanes10. DSI                                                            1                1  port 4 lanes11. DMIC                                                       2  12. GPIOs                                                     20  13. I2S                                                           2                     1 is for WCD9370
► 技术文档
类型
标题
档案
硬件
keypart
[url=][/url]
GMT+8, 2026-5-10 06:42 , Processed in 1.453358 second(s), 41 queries .
