查看: 1643|回复: 0
Debian/Ubuntu 报错解决:-bash: ifconfig: command not found
发表于 2022-4-28 09:17:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在WSL里安装了最新的 Debian,然后想查看ip地址的时候报错了:
  1. fan@SUN-ACC:/bin$ ifconfig
  2. -bash: ifconfig: command not found
出现这个问题的原因是新版本的Debian 默认不带 ifconfig,官方推荐使用ip命令查看ip:
  1. fan@SUN-ACC:/bin$ ip addr
  2. 16: eth0: <BROADCAST,MULTICAST,UP> mtu 1500 group default qlen 1
  3.     link/ether 2c:f0:5d:6c:a5:ca
  4.     inet 192.168.0.38/24 brd 192.168.0.255 scope global dynamic
  5.        valid_lft 496376251sec preferred_lft 496376251sec
  6.     inet6 fe80::4898:fabc:f0fa:80af/64 scope link dynamic
  7.        valid_lft forever preferred_lft forever
  8. 17: eth1: <BROADCAST,MULTICAST,UP> mtu 1500 group default qlen 1
  9.     link/ether 00:50:56:c0:00:01
  10.     inet 192.168.118.1/24 brd 192.168.118.255 scope global dynamic
  11.        valid_lft 906sec preferred_lft 906sec
  12.     inet6 fe80::713d:625e:8939:d142/64 scope link dynamic
  13.        valid_lft forever preferred_lft forever
  14. 14: eth2: <BROADCAST,MULTICAST,UP> mtu 1500 group default qlen 1
  15.     link/ether 00:50:56:c0:00:08
  16.     inet 192.168.73.1/24 brd 192.168.73.255 scope global dynamic
  17.        valid_lft 1799sec preferred_lft 1799sec
  18.     inet6 fe80::8999:7c1c:1a9f:3190/64 scope link dynamic
  19.        valid_lft forever preferred_lft forever
  20. 1: lo: <LOOPBACK,UP> mtu 1500 group default qlen 1
  21.     link/loopback 00:00:00:00:00:00
  22.     inet 127.0.0.1/8 brd 127.255.255.255 scope global dynamic
  23.        valid_lft forever preferred_lft forever
  24.     inet6 ::1/128 scope host dynamic
  25.        valid_lft forever preferred_lft forever
如果还想使用ifconfig命令,需要安装包:
  1. fan@SUN-ACC:/bin$ sudo apt-get install net-tools
  2. [sudo] password for fan:
  3. Reading package lists... Done
  4. Building dependency tree... Done
  5. Reading state information... Done
  6. The following NEW packages will be installed:
  7.   net-tools
  8. 0 upgraded, 1 newly installed, 0 to remove and 30 not upgraded.
  9. Need to get 250 kB of archives.
  10. After this operation, 1,015 kB of additional disk space will be used.
  11. Get:1 http://deb.debian.org/debian bullseye/main amd64 net-tools amd64 1.60+git20181103.0eebece-1 [250 kB]
  12. Err:1 http://deb.debian.org/debian bullseye/main amd64 net-tools amd64 1.60+git20181103.0eebece-1
  13.   Connection timed out [IP: 151.101.230.132 80]
  14. E: Failed to fetch http://deb.debian.org/debian/pool/main/n/net-tools/net-tools_1.60%2bgit20181103.0eebece-1_amd64.deb  Connection timed out [IP: 151.101.230.132 80]
  15. E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
安装时会出现错误,用按提示修复
  1. fan@SUN-ACC:/bin$ sudo apt-get update --fix-missing
  2. Get:1 http://ftp.debian.org/debian bullseye-backports InRelease [44.2 kB]
  3. Get:2 http://security.debian.org/debian-security bullseye-security InRelease [44.1 kB]
  4. Hit:3 http://deb.debian.org/debian bullseye InRelease
  5. Get:4 http://deb.debian.org/debian bullseye-updates InRelease [39.4 kB]
  6. Err:2 http://security.debian.org/debian-security bullseye-security InRelease
  7.   Connection timed out [IP: 151.101.230.132 80]
  8. Err:1 http://ftp.debian.org/debian bullseye-backports InRelease
  9.   Connection timed out [IP: 151.101.230.132 80]
  10. Fetched 39.4 kB in 1min 8s (582 B/s)
  11. Reading package lists... Done
  12. W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Connection timed out [IP: 151.101.230.132 80]
  13. W: Failed to fetch http://ftp.debian.org/debian/dists/bullseye-backports/InRelease  Connection timed out [IP: 151.101.230.132 80]
  14. W: Some index files failed to download. They have been ignored, or old ones used instead.
再次安装
  2. Reading package lists... Done
  3. Building dependency tree... Done
  4. Reading state information... Done
  5. The following NEW packages will be installed:
  6.   net-tools
  7. 0 upgraded, 1 newly installed, 0 to remove and 30 not upgraded.
  8. Need to get 250 kB of archives.
  9. After this operation, 1,015 kB of additional disk space will be used.
  10. Get:1 http://deb.debian.org/debian bullseye/main amd64 net-tools amd64 1.60+git20181103.0eebece-1 [250 kB]
  11. Fetched 250 kB in 5s (51.8 kB/s)
  12. Selecting previously unselected package net-tools.
  13. (Reading database ... 19148 files and directories currently installed.)
  14. Preparing to unpack .../net-tools_1.60+git20181103.0eebece-1_amd64.deb ...
  15. Unpacking net-tools (1.60+git20181103.0eebece-1) ...
  16. Setting up net-tools (1.60+git20181103.0eebece-1) ...
安装成功了!!!试试吧
  2. eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
  3.         inet 192.168.0.38  netmask 255.255.255.0  broadcast 192.168.0.255
  4.         inet6 fe80::4898:fabc:f0fa:80af  prefixlen 64  scopeid 0xfd<compat,link,site,host>
  5.         ether 2c:f0:5d:6c:a5:ca  (Ethernet)
  6.         RX packets 0  bytes 0 (0.0 B)
  7.         RX errors 0  dropped 0  overruns 0  frame 0
  8.         TX packets 0  bytes 0 (0.0 B)
  9.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  10. eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
  11.         inet 192.168.118.1  netmask 255.255.255.0  broadcast 192.168.118.255
  12.         inet6 fe80::713d:625e:8939:d142  prefixlen 64  scopeid 0xfd<compat,link,site,host>
  13.         ether 00:50:56:c0:00:01  (Ethernet)
  14.         RX packets 0  bytes 0 (0.0 B)
  15.         RX errors 0  dropped 0  overruns 0  frame 0
  16.         TX packets 0  bytes 0 (0.0 B)
  17.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  18. eth2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
  19.         inet 192.168.73.1  netmask 255.255.255.0  broadcast 192.168.73.255
  20.         inet6 fe80::8999:7c1c:1a9f:3190  prefixlen 64  scopeid 0xfd<compat,link,site,host>
  21.         ether 00:50:56:c0:00:08  (Ethernet)
  22.         RX packets 0  bytes 0 (0.0 B)
  23.         RX errors 0  dropped 0  overruns 0  frame 0
  24.         TX packets 0  bytes 0 (0.0 B)
  25.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  26. lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 1500
  27.         inet 127.0.0.1  netmask 255.0.0.0
  28.         inet6 ::1  prefixlen 128  scopeid 0xfe<compat,link,site,host>
  29.         loop  (Local Loopback)
  30.         RX packets 0  bytes 0 (0.0 B)
  31.         RX errors 0  dropped 0  overruns 0  frame 0
  32.         TX packets 0  bytes 0 (0.0 B)
  33.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
Yes 真的成功了
GMT+8, 2026-5-29 23:01 , Processed in 0.144298 second(s), 37 queries .
