查看: 4564|回复: 0
ELTEX UPG16720/16730Stitch16750 16760缝纫线断线检测器资料下载
发表于 2021-11-10 23:56:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Eltex UPG断纱检测器缝纫线检测器16720/16730
    UPG断纱检测器小巧通用,利用压电原理检测纱线的运动。它工作原理使适用于所有类型的纱线,而不敏感于灰尘。
     检测器光耦开关信号输出,可以PLC和其它电气控制设备相连接。
     有LED指示纱线的活动状态。
功能特性
传感部件                    氧化铝陶瓷眼,孔径Ø3 mm,宽7 mm
输出                          光电开关,无纱运动为闭合状态
灵敏度调节                   调节底部的电位器
当有纱线运动时,光电开关是开路的,当无纱运动时,为闭合状态。
LED灯亮指示为有纱线运动。
检测器的电缆连接有6/4水晶头,可多个检测器并联,还带反电压保护。
应用范例
络筒设备
捻机
缝纫机
纱线准备机
纺纱机
变形机.
包纱机
双杆或多杆织机
喷气织机
技术参数
电源              20 mA
输出:
     最大电流        10 mA
     最大压降           2 V
延时               150 ms
连接电缆长
     16720             0.5 m
     16730             3.5 m
转速区间                600 - 10000 rpm
      16750                 0.5m连接线
      16760                 3.5m连接线
连接器             6/4 水晶头
瑞典ELTEX简介
瑞典ELTEX 有40 余年的经验,是纺织机械行业的**者。ELTEX丰富的生产经验和精湛的制造技术**设计理念,使得创造的传感器更加**,**于行业水平.
Eltex UPG yarn break detector thread break detector 16720/16730
General description
The UPG is a small, general purpose, thread break detector. It operates on the piezoelectric principle, detecting the yarn movement. This working principle makes it suitable for all types of yarn and makes it insensitive to dust, dirt and humidity variations.
The detector has an opto-coupler output suitable for PLC or other electronic control devices.
A LED (light emitting diode) indicates the yarn movement.
The ceramic sensor part can be used either as a closed eyelet or as an open bar. Several detectors can be connected in parallel.
Function description
Sensing part                     Aluminium oxide ceramic, with a Ø3 mm closed eyelet and a 7 mm wide bar.
Output                              Opto-coupler, active when yarn isnot moving.
Sensitivity setting           The sensitivity can be adjusted with a potentiometer under the lid.
The output reflects the movement of the yarn. When the yarn is moving, the optocoupler is inactive. When the yarn is not moving, the optocoupler is active.
The LED is on when the yarn is moving.
The detector is supplied with cable and a 6/4 modular plug connector. Many thread detectors can be connected in parallel. The detector is protected against wrong polarity on power supply.
Application examples
Winders.
Twisters.
Sewing machines.
Yarn preparation machines.
Spinning machines.
Texturing machines.
Covering machines.
Double/multiple picks on
airjet weaving machines.
Technical specifications
Housing in zinc metal
Power supply                           15–30 V DC
Current consumption                 20 mA
Output:
        Max. switching current      10 mA
        Max. voltage drop             2 V
Reaction time                           150 ms
Cable length
          16720                            0.5 m
          16730                            3.5 m
Cable connector                        6/4 modular plug connector
资料下载
UPG型缝纫传感器应用文档.pdf (189.87 KB, 下载次数: 2)
Eltex UPG yarn break detector 16720.pdf (135.25 KB, 下载次数: 3)
GMT+8, 2026-5-24 08:59 , Processed in 0.132254 second(s), 39 queries .
