NXP Zigbee JN516X JN517x JN518X 用vsCode studio 环境开发编译
2023-4-26 22:47| 发布者: 谷谷小师妹| 查看: 47| 评论: 1|原作者: sunsili
摘要: NXP Zigbee JN516X JN517x JN518X 用vsCode studio 环境开发编译 官方推荐是用Beyond IDE开发,不方便,搭建开发环境,安装插件基本不是成功的。 i have a problem to install the plugin Zbee pro configuration edi ...
i have a problem to install the plugin Zbee pro configuration editor
with sdk JN-4141
the version of beyond studio  is : Build 1308
sdk jn 4170 is : Build Number 1745
I've reinstalled it twice in the default path and on D drive, and it still doesn't work.
when i install the plugin (ZB pro configuration edition 2.0.0), i have the message error :Cannot complete the install because one or more required items could not be found.
Software being installed: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
Missing requirement: ZBPro Config Edit Support 2.0.0 (com.jennic.zps.configeditor.edit 2.0.0) requires 'bundle org.eclipse.emf.edit 0.0.0' but it could not be found
Cannot satisfy dependency:
From: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
To: com.jennic.zps.configeditor.edit [2.0.0]
以上摘自NXP社区,碰到这样问题的用户非常多, 我也碰到, 于是想到用VSCODE。
准备
安装visual code studio(microsoft官网下载, 安装过程过于简单不再赘述)
安装EIDE插件
下载SKD(JN516x---JN-SW4170,Jn517x---JN-SW-4270) 安装后, 复制到NXP_JN工作目录,不用要中文 参考:【ZigBee 系列】|NXP-JN5169 ZigBee 3.0 开发环境搭建及编译-谷动谷力 (sunsili.com)
下载NXP Zigeeb工程源码示例
如下:
Coordinator:
适合应用场景:网关。
JN-AN-1216-Zigbee-3-0-IoT-ControlBridge
JN-AN-1217-Zigbee-3-0-Base-Device
Router:
适合应用场景:长供电应用,例如各类灯应用、插座。
JN-AN-1218-Zigbee-3-0-Light-Bulb
End Device:
适合应用场景:低功耗休眠应用、各类传感器应用、开关控制器,例如温湿度传感器、烟雾报警器等。
JN-AN-1219-Zigbee-3-0-Controller-and-Switch
JN-AN-1220-Zigbee-3-0-Sensors
Test Code:
适用于测试射频参数,功耗等硬件指标。
JN-AN-1172-JN516x-Customer-Module-Evaluation-Tool
更多内容请参阅:NXP Zigbee JN5169 软件开发流程-SDK 及 AN 介绍与选择-谷动谷力 (sunsili.com)
实战操作
解压 源码JN-AN-1219\JN-AN-1219-Zigbee-3-0-Controller-and-Switch
在“资源资源管理器” -右键“用vsCode打开”
或用vsCode“文件”-“打开文件夹” 打开JN-AN-1219\JN-AN-1219-Zigbee-3-0-Controller-and-Switch文件夹
打开Eide msys bash 终端
到子工程目录下的build 下
输入命令:
make JENNIC_CHIP=JN5169 JENNIC_CHIP_FAMILY=JN516x REMOTE=ColorSceneController DR=DR1199 TRACE=1 all
或修改Makefile
#User definable make parameters that may be overwritten from the command line
# Default target device is the JN5179
JENNIC_CHIP ?= JN5179  #芯片型号
JENNIC_CHIP_FAMILY ?= JN517x #系列
ifeq ($(JENNIC_CHIP_FAMILY),JN517x)
    ENDIAN ?= LITTLE_ENDIAN
endif
ifeq ($(JENNIC_CHIP_FAMILY),JN516x)
    JENNIC_SDK ?= JN-SW-4170
    JENNIC_PCB ?= DEVKIT4
else
    JENNIC_SDK ?= JN-SW-4270
    JENNIC_PCB ?= DEVKIT5
endif
选择芯片型号
修改工程名(目标)# Application target name
TARGET = EH_Switch #工程名
CFLAGS += -DPDM_USER_SUPPLIED_ID
CFLAGS += -DPDM_NO_RTOS
CFLAGS +=  -DEH_Switch
PDM_BUILD_TYPE = _EEPROM
CFLAGS += -DPDM$(PDM_BUILD_TYPE)
编译SDK、工程路径(没配置好,编译会报错)
# Use if application directory contains single target
SDK_BASE_DIR            = $(abspath ../../../../sdk/$(JENNIC_SDK))
APP_BASE                = $(abspath ..)
APP_BLD_DIR             = $(APP_BASE)/Build
APP_SRC_DIR             = $(APP_BASE)/Source
APP_COMMON_SRC_DIR      = $(APP_BASE)/../Common/Source
MMAC_DIR                = $(APP_BASE)/../../Components/MMAC/Include
LIB_DIR                 = $(APP_BASE)/../Components/Library
ZIGBEE_COMMON_SRC       = $(COMPONENTS_BASE_DIR)/ZigbeeCommon/Source
编译前先clean
make clean
编译
make -j8(8线程,只要电脑支持线程多,比IDE编译快多了)
鸣涧 2024-4-14 12:26
JN-AN-1907... Makefiles配置
  1. TARGET = JN-AN-1907-Zigbee-Valve-Controller-JN5169
  2. DEV_TYPE = ValveController
  3. #  Note: Target name must be the same as the subfolder name
  4. ##############################################################################
  5. #User definable make parameters that may be overwritten from the command line
  6. # Default target device is the JN5148
  7. JENNIC_CHIP ?= JN5169
  8. ##############################################################################
  9. # Default DK2 development kit target hardware
  10. JENNIC_PCB ?= DEVKIT4
  11. ##############################################################################
  12. # Select the network stack (e.g. MAC, ZBPRO)
  13. JENNIC_STACK ?= MAC
  14. ##############################################################################
  15. # Debug options define DEBUG for HW debug
  16. #DEBUG ?=HW
  17. #
  18. #
  19. # Define which UART to use for debug
  20. DEBUG_PORT ?= UART1
  21. ##############################################################################
  22. # Define TRACE to use with DBG module
  23. TRACE ?= 1
  24. ##############################################################################
  25. # Define configuration
  26. ifeq ($(FLOW_CONTROL), NO_FLOW_CONTROL)
  27.         CFLAGS  += -DENABLE_NO_FLOW_CONTROL
  28.         BIN_SUFFIX = _NO_FLOW_CTRL
  29. endif
  30. ifeq ($(FLOW_CONTROL), HW_FLOW_CONTROL)
  31.         CFLAGS  += -DENABLE_HW_FLOW_CONTROL
  32.         BIN_SUFFIX = _HW_FLOW_CTRL
  33. endif
  34. ifeq ($(FLOW_CONTROL), HW_SW_FLOW_CONTROL)
  35.         CFLAGS  += -DENABLE_HW_SW_FLOW_CONTROL
  36.         BIN_SUFFIX = _HW_SW_FLOW_CTRL
  37. endif
  38. ##############################################################################
  39. ##############################################################################
  40. ##############################################################################
  41. # Path definitions
  42. # Select definitions for either single or multiple targets
  43. # Use if application directory contains multiple targets
  44. SDK_BASE_DIR                    = $(abspath ../../../sdk/JN-SW-4163)
  45. LZSTACK_BASE_DIR           = $(abspath ../../..)
  46. APP_BASE            = $(abspath ../..)
  47. APP_BLD_DIR         = $(APP_BASE)/$(DEV_TYPE)/Build
  48. APP_SRC_DIR         = $(APP_BASE)/$(DEV_TYPE)/Source
  49. APP_COMMON_SRC_DIR         = $(APP_BASE)/Common/Source
  50. JENOS_DIR                        = $(LZSTACK_BASE_DIR)/LZStackV5/JenOS
  51. STACK_DIR                        = $(LZSTACK_BASE_DIR)/LZStackV5/stack
  52. STACK_MAC_DIR                = $(LZSTACK_BASE_DIR)/LZStackV5/stack/mac
  53. STACK_NWK_DIR                = $(LZSTACK_BASE_DIR)/LZStackV5/stack/nwk
  54. STACK_ZDO_DIR                = $(LZSTACK_BASE_DIR)/LZStackV5/stack/zdo
  55. STACK_APS_DIR                = $(LZSTACK_BASE_DIR)/LZStackV5/stack/aps
  56. STACK_COMMON_DIR        = $(LZSTACK_BASE_DIR)/LZStackV5/common
GMT+8, 2025-10-24 18:20 , Processed in 0.089834 second(s), 36 queries .
