查看: 4003|回复: 0
RT-Thread Audio - 1. 音频框架的分析
发表于 2021-12-9 13:53:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Github 上 RT-Thread 源码最新更新了关于 Audio 驱动相关的部分,让上层和底层都开发和编程简单了,不过对于大部分的开发者来说还不太熟悉这套框架的,那么笔者就这次编写音频驱动给大家分析下代码框架。
这里会先贴一张框架图,整个帖子都是笔者在编写开发过程中写的,可能有格式和错误,最终全部更新完毕后会整理整个系列的帖子。
1. RT-Thread 音频架构图
2. RT-Thread 音频框架的调用逻辑关系图(建议右键大图)
3. RT-Thread 音频应用代码模板(以wavplay为例)
https://github.com/RT-Thread-packages/wavplayer
4. RT-Thread 音频驱动代码模板
  1. #include "drv_sound.h"
  2. #include "drv_tina.h"
  3. #include "drivers/audio.h"
  4. #define DBG_TAG "drv_sound"
  5. #define DBG_LVL DBG_LOG
  6. #define DBG_COLOR
  7. #include
  8. #define TX_DMA_FIFO_SIZE (2048)
  9. struct temp_sound
  10. {
  11. struct rt_audio_device device;
  12. struct rt_audio_configure replay_config;
  13. int volume;
  14. rt_uint8_t *tx_fifo;
  15. };
  16. static rt_err_t getcaps(struct rt_audio_device *audio, struct rt_audio_caps *caps)
  17. {
  18. struct temp_sound *sound = RT_NULL;
  19. RT_ASSERT(audio != RT_NULL);
  20. sound = (struct temp_sound *)audio->parent.user_data; (void)sound;
  21. return RT_EOK;
  22. }
  23. static rt_err_t configure(struct rt_audio_device *audio, struct rt_audio_caps *caps)
  24. {
  25. struct temp_sound *sound = RT_NULL;
  26. RT_ASSERT(audio != RT_NULL);
  27. sound = (struct temp_sound *)audio->parent.user_data; (void)sound;
  28. return RT_EOK;
  29. }
  30. static rt_err_t init(struct rt_audio_device *audio)
  31. {
  32. struct temp_sound *sound = RT_NULL;
  33. RT_ASSERT(audio != RT_NULL);
  34. sound = (struct temp_sound *)audio->parent.user_data; (void)sound;
  35. return RT_EOK;
  36. }
  37. static rt_err_t start(struct rt_audio_device *audio, int stream)
  38. {
  39. struct temp_sound *sound = RT_NULL;
  40. RT_ASSERT(audio != RT_NULL);
  41. sound = (struct temp_sound *)audio->parent.user_data; (void)sound;
  42. return RT_EOK;
  43. }
  44. static rt_err_t stop(struct rt_audio_device *audio, int stream)
  45. {
  46. struct temp_sound *sound = RT_NULL;
  47. RT_ASSERT(audio != RT_NULL);
  48. sound = (struct temp_sound *)audio->parent.user_data; (void)sound;
  49. return RT_EOK;
  50. }
  51. rt_size_t transmit(struct rt_audio_device *audio, const void *writeBuf, void *readBuf, rt_size_t size)
  52. {
  53. struct temp_sound *sound = RT_NULL;
  54. RT_ASSERT(audio != RT_NULL);
  55. sound = (struct temp_sound *)audio->parent.user_data; (void)sound;
  56. return size;
  57. }
  58. static void buffer_info(struct rt_audio_device *audio, struct rt_audio_buf_info *info)
  59. {
  60. struct temp_sound *sound = RT_NULL;
  61. RT_ASSERT(audio != RT_NULL);
  62. sound = (struct temp_sound *)audio->parent.user_data;
  63. /**
  64. * TX_FIFO
  65. * +----------------+----------------+
  66. * | block1 | block2 |
  67. * +----------------+----------------+
  68. * \ block_size /
  69. */
  70. info->buffer = sound->tx_fifo;
  71. info->total_size = TX_DMA_FIFO_SIZE;
  72. info->block_size = TX_DMA_FIFO_SIZE / 2;
  73. info->block_count = 2;
  74. }
  75. static struct rt_audio_ops ops =
  76. {
  77. .getcaps = getcaps,
  78. .configure = configure,
  79. .init = init,
  80. .start = start,
  81. .stop = stop,
  82. .transmit = transmit,
  83. .buffer_info = buffer_info,
  84. };
  85. static int rt_hw_sound_init(void)
  86. {
  87. rt_uint8_t *tx_fifo = RT_NULL;
  88. static struct temp_sound sound = {0};
  89. /* 分配 DMA 搬运 buffer */
  90. tx_fifo = rt_calloc(1, TX_DMA_FIFO_SIZE);
  91. if(tx_fifo == RT_NULL)
  92. {
  93. return -RT_ENOMEM;
  94. }
  95. sound.tx_fifo = tx_fifo;
  96. /* 注册声卡放音驱动 */
  97. sound.device.ops = &ops;
  98. rt_audio_register(&sound.device, "sound0", RT_DEVICE_FLAG_WRONLY, &sound);
  99. return RT_EOK;
  100. }
  101. INIT_DEVICE_EXPORT(rt_hw_sound_init);
5. 代码分析
待后续补充。。。
下载附件[sound_temp.7z]
GMT+8, 2026-4-2 19:47 , Processed in 0.095054 second(s), 39 queries .
