查看: 26464|回复: 3
【Openwrt】开发环境搭建 编译openwrt源码
发表于 2021-1-16 21:45:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
前言
openwrt源码的编译相对简单,部分编译过程中出现问题可能是由于用的是root用户,现在 winddows10带wrl-ubuntu虚拟机很棒的,我用的是Ubuntu, 默认是没有提供root用户, 如果切换成普通用户下载并编译可能会更顺利一些。
获取openwrt源码
下载openwrt源码 ,注意要用gitee国内站,如用用的github国外站慢的开始怀疑人生。编译时常会出问题,希望一切胜利 , Good luck
$ git clone https://gitee.com/mirrors/openwrt.git -b <分支版本>
当下载好openwrt源码后,进入openwrt文件夹
$ cd openwrt/
查看openwrt文件夹内容
$ ls
列出文件夹的内容如下
BSDmakefile  config  Config.in  feeds.conf.default  include  LICENSE  Makefile  package  README  rules.mk  scripts  target  toolchain  tools
对于上述出现的文件,首先第一步要看的内容就是  README
$ cat README
出现内容如下所示
  _______                     ________        __
|       |.-----.-----.-----.|  |  |  |.----.|  |_
|   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
|_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
This is the buildsystem for the OpenWrt Linux distribution.
To build your own firmware you need a Linux, BSD or MacOSX system (casesensitive filesystem required). Cygwin is unsupported because of the lackof a case sensitive file system.
You need gcc, binutils, bzip2, flex, python3.5+, perl, make, find, grep, diff,unzip, gawk, getopt, subversion, libz-dev and libc headers installed.
1. Run "./scripts/feeds update -a" to obtain all the latest package definitionsdefined in feeds.conf / feeds.conf.default
2. Run "./scripts/feeds install -a" to install symlinks for all obtainedpackages into package/feeds/
3. Run "make menuconfig" to select your preferred configuration for thetoolchain, target system & firmware packages.
4. Run "make" to build your firmware. This will download all sources, buildthe cross-compile toolchain and then cross-compile the Linux kernel & allchosen applications for your target system.
Sunshine!        Your OpenWrt Community        http://www.openwrt.org
"README" 34L, 1299C        1,1           All
Openwrt开发环境搭建
阅读README内容,openwrt开发环境安装依赖工具链以及库:gcc, binutils, bzip2, flex, python3.5+, perl, make, find, grep, diff,unzip, gawk, getopt, subversion, libz-dev 和 libc
安装库以及工具链(依我的经验多加了一些)
sudo apt-get update
sudo apt-get install git g++ make libncurses5-dev subversion libssl-dev gawk libxml-parser-perl unzip wget python xz-utils vim zlibc zlib1g zlib1g-dev  build-essential ccache gettext xsltproc flex patch asciidoc binutils bzip2  bison  autoconf sharutils ncurses-term
如果是 64 位操作系统,需要多操作如下步骤:(注意libc6:i386 libncurses5:i386 libstdc++6:i386 中间要加冒号)
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386
编译openwrt源码
阅读README,有步骤1.2.3.4.共四步。这四步就是openwrt源码的编译步骤。
如下
1、更新源码包
$ ./scripts/feeds update -a
2、安装到/package/feeds
3、编译配置
$ make menuconfig
可能会出错
Build dependency: Please install the GNU C++ Compiler (g++).  //安装 gcc g++  如果要编译ARM平台 需要arm-linux-gcc
Build dependency: Please install ncurses. (Missing libncurses.so or ncurses.h)  //安装ncurese
Build dependency: Please install zlib. (Missing libz.so or zlib.h) //安装zlib
Build dependency: Please install GNU awk.  www.2cto.com  //sudo apt-get install gawk 注意名称
Build dependency: Please install flex. //安装flex
Build dependency: Please install patch. //安装pathc
Build dependency: Please install git (git-core). //安装git
Build dependency: Please install the subversion client.  //安装subversion client
环境检测通过的话,运行到这步的时候会出现openwrt的配置界面
各种参数即可通过这里设置。
将Target Profile 设置为 可支持硬件板子
Target Profile
  1. Multiple devices (TARGET_MULTI_PROFILE)   //多种硬件
2. Broadcom SoC, BCM43xx WiFi (b43, brcmfmac, default) (TARGET_bcm53xx_generic_Generic)    //博通的Soc
  3. ASUS RT-AC56U (TARGET_bcm53xx_generic_DEVICE_asus_rt-ac56u)  //华硕主板
  4. ASUS RT-AC68U (TARGET_bcm53xx_generic_DEVICE_asus_rt-ac68u)
  5. ASUS RT-AC87U (TARGET_bcm53xx_generic_DEVICE_asus_rt-ac87u)
  6. ASUS RT-N18U (TARGET_bcm53xx_generic_DEVICE_asus_rt-n18u)
  7. Buffalo WXR-1900DHP (TARGET_bcm53xx_generic_DEVICE_buffalo_wxr-1900dhp)  //我不认识这个了
  8. Buffalo WZR-600DHP2 (TARGET_bcm53xx_generic_DEVICE_buffalo_wzr-600dhp2)
  9. Buffalo WZR-900DHP (TARGET_bcm53xx_generic_DEVICE_buffalo_wzr-900dhp)
  10. Buffalo WZR-1750DHP (TARGET_bcm53xx_generic_DEVICE_buffalo_wzr-1750dhp)
  11. D-Link DIR-885L (TARGET_bcm53xx_generic_DEVICE_dlink_dir-885l)  //D-Link DIR-885L路由器
  12. Linksys EA6300 v1 (TARGET_bcm53xx_generic_DEVICE_linksys_ea6300-v1)  //以下的都不识
  13. Linksys EA6500 v2 (TARGET_bcm53xx_generic_DEVICE_linksys_ea6500-v2)
  14. Linksys EA9200 v1 (TARGET_bcm53xx_generic_DEVICE_linksys_ea9200)
  15. Linksys EA9500 (TARGET_bcm53xx_generic_DEVICE_linksys_ea9500)
  16. Luxul ABR-4500 (TARGET_bcm53xx_generic_DEVICE_luxul_abr-4500)
  17. Luxul XAP-1610 (TARGET_bcm53xx_generic_DEVICE_luxul_xap-1610)
  18. Luxul XBR-4500 (TARGET_bcm53xx_generic_DEVICE_luxul_xbr-4500)
  19. Luxul XWR-3150 (TARGET_bcm53xx_generic_DEVICE_luxul_xwr-3150)
  20. Meraki MR32 (TARGET_bcm53xx_generic_DEVICE_meraki_mr32)
  21. NETGEAR R6250 (TARGET_bcm53xx_generic_DEVICE_netgear_r6250)
  22. NETGEAR R6300 v2 (TARGET_bcm53xx_generic_DEVICE_netgear_r6300-v2)
  23. NETGEAR R7000 (TARGET_bcm53xx_generic_DEVICE_netgear_r7000)
  24. NETGEAR R7900 (TARGET_bcm53xx_generic_DEVICE_netgear_r7900)
  25. NETGEAR R8000 (TARGET_bcm53xx_generic_DEVICE_netgear_r8000)
  26. NETGEAR R8500 (TARGET_bcm53xx_generic_DEVICE_netgear_r8500)
  27. SmartRG SR400ac (TARGET_bcm53xx_generic_DEVICE_smartrg_sr400ac)
  28. PHICOMM K3 (TARGET_bcm53xx_generic_DEVICE_phicomm_k3)   //小米 PHICOMM K3路由器
  29. Tenda AC9 (TARGET_bcm53xx_generic_DEVICE_tenda_ac9)  //腾达 AC9路由器
  30. TP-Link Archer C5 v2 (TARGET_bcm53xx_generic_DEVICE_tplink_archer-c5-v2)  //TP-Link Archer C5 路由器
  31. TP-Link Archer C9 v1 (TARGET_bcm53xx_generic_DEVICE_tplink_archer-c9-v1) //TP-Link Archer C9 路由器
市场上路由基本上用OpenWrt做的。
我的开发板是MT7628的选择
MediaTek Ralink MIPS(MTK MIPS)
Subtarget(MT76x8 base boards)
选择Package the OpenWrt-base Toolchain是为了有搭建交叉编译环境方便,不是必选的。
Target System (MediaTek Ralink MIPS) --->
        Subtarget (MT76x8 based boards) --->
                Target Profile (Jotale JS76x8 16M)
LuCI  --->
        1. Collections  --->
                <*> luci................... LuCI interface with Uhttpd as Webserver (default)
此外,勾选LuCI(网页形式的控制台)还是非常必要的。要勾选(前面出现*号):
最后Save,退出。
以上是基本的固件编译,如果需要其他功能,要再勾选或添加。
4、最后 make 编译
$ make -j10
编码出错了,
package/utils/busybox/Makefile' has a dependency on 'libpam', which does not exist
不写了,解决问题后,下回写吧
(编译出错是正常的,后面会相关总结,每次编译出错,我都会记录下来)
编译好了,找个设备试试吧!
+116
沙发
发表于 2023-7-13 20:26:51 | 只看该作者
板凳
发表于 2023-10-25 11:05:10 | 只看该作者
不错
地板
发表于 2023-11-17 09:55:10 | 只看该作者
赞一个
GMT+8, 2026-4-26 09:39 , Processed in 0.218202 second(s), 49 queries .
