查看: 4762|回复: 1
【BLE蓝牙】GAC Gatt UUID列表
发表于 2021-12-6 15:27:25 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
最近在研究BLE蓝牙,顺便把官网上的UUID列表对应类型翻译了一下,水平一般(大多采用有道、谷歌翻译,外加自己的理解对翻译进行校正),仅做参考。如果有翻译不正确的地方还望指出。
GATT services (服务):
官网地址:https://www.bluetooth.com/specifications/gatt/services/
名称        中文释义        统一类型ID        分配的号码        规范
Generic Access        通用访问        org.bluetooth.service.generic_access        0x1800        GSS
Alert Notification Service        闹钟通知        org.bluetooth.service.alert_notification        0x1811        GSS
Automation IO        自动化输入输出        org.bluetooth.service.automation_io        0x1815        GSS
Battery Service        电池数据        org.bluetooth.service.battery_service        0x180F        GSS
Binary Sensor        二元传感器        GATT Service UUID        0x183B        BSS
Blood Pressure        血压        org.bluetooth.service.blood_pressure        0x1810        GSS
Body Composition        身体组成        org.bluetooth.service.body_composition        0x181B        GSS
Bond Management Service        设备绑定管理        org.bluetooth.service.bond_management        0x181E        GSS
Continuous Glucose Monitoring        动态血糖检测        org.bluetooth.service.continuous_glucose_monitoring        0x181F        GSS
Current Time Service        当前时间        org.bluetooth.service.current_time        0x1805        GSS
Cycling Power        骑行能量        org.bluetooth.service.cycling_power        0x1818        GSS
Cycling Speed and Cadence        循环速度、节奏        org.bluetooth.service.cycling_speed_and_cadence        0x1816        GSS
Device Information        设备信息        org.bluetooth.service.device_information        0x180A        GSS
Emergency Configuration        应急配置        GATT Service UUID        0x183C        EMCS
Environmental Sensing        环境传感        org.bluetooth.service.environmental_sensing        0x181A        GSS
Fitness Machine        健康设备        org.bluetooth.service.fitness_machine        0x1826        GSS
Generic Attribute        通用属性        org.bluetooth.service.generic_attribute        0x1801        GSS
Glucose        葡萄糖        org.bluetooth.service.glucose        0x1808        GSS
Health Thermometer        温度计        org.bluetooth.service.health_thermometer        0x1809        GSS
Heart Rate        心率        org.bluetooth.service.heart_rate        0x180D        GSS
HTTP Proxy        HTTP代理        org.bluetooth.service.http_proxy        0x1823        GSS
Human Interface Device        HID设备        org.bluetooth.service.human_interface_device        0x1812        GSS
Immediate Alert        即时闹钟        org.bluetooth.service.immediate_alert        0x1802        GSS
Indoor Positioning        室内定位        org.bluetooth.service.indoor_positioning        0x1821        GSS
Insulin Delivery        胰岛素给药        org.bluetooth.service.insulin_delivery        0x183A        GSS
Internet Protocol Support Service        互联网协议支持        org.bluetooth.service.internet_protocol_support        0x1820        GSS
Link Loss        连接丢失        org.bluetooth.service.link_loss        0x1803        GSS
Location and Navigation        定位及导航        org.bluetooth.service.location_and_navigation        0x1819        GSS
Mesh Provisioning Service        节点配置        org.bluetooth.service.mesh_provisioning        0x1827        GSS
Mesh Proxy Service        节点代理        org.bluetooth.service.mesh_proxy        0x1828        GSS
Next DST Change Service        下个日光节约时间(夏令时)更改        org.bluetooth.service.next_dst_change        0x1807        GSS
Object Transfer Service        对象传输        org.bluetooth.service.object_transfer        0x1825        GSS
Phone Alert Status Service        手机报警状态        org.bluetooth.service.phone_alert_status        0x180E        GSS
Pulse Oximeter Service        脉搏血氧计        org.bluetooth.service.pulse_oximeter        0x1822        GSS
Reconnection Configuration        重连配置        org.bluetooth.service.reconnection_configuration        0x1829        GSS
Reference Time Update Service        参照时间更新        org.bluetooth.service.reference_time_update        0x1806        GSS
Running Speed and Cadence        跑步速度、节奏        org.bluetooth.service.running_speed_and_cadence        0x1814        GSS
Scan Parameters        扫描参数        org.bluetooth.service.scan_parameters        0x1813        GSS
Transport Discovery        传输发现        org.bluetooth.service.transport_discovery        0x1824        GSS
Tx Power        发送功率        org.bluetooth.service.tx_power        0x1804        GSS
User Data        用户数据        org.bluetooth.service.user_data        0x181C        GSS
Weight Scale        体重秤        org.bluetooth.service.weight_scale        0x181D        GSS
版权声明:本文为CSDN博主「hrx-@@」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/lang523493505/article/details/103474961
沙发
 楼主| 发表于 2021-12-6 15:29:33 | 只看该作者
GATT descriptors(描述符):
官网地址:https://www.bluetooth.com/specifications/gatt/descriptors/
Characteristic Aggregate Format        特征汇总格式        org.bluetooth.descriptor.gatt.characteristic_aggregate_format        0x2905        GSS
Characteristic Extended Properties        特性扩展属性        org.bluetooth.descriptor.gatt.characteristic_extended_properties        0x2900        GSS
Characteristic Presentation Format        特征描述格式        org.bluetooth.descriptor.gatt.characteristic_presentation_format        0x2904        GSS
Characteristic User Description        特征用户描述        org.bluetooth.descriptor.gatt.characteristic_user_description        0x2901        GSS
Client Characteristic Configuration        客户端特征配置        org.bluetooth.descriptor.gatt.client_characteristic_configuration        0x2902        GSS
Environmental Sensing Configuration        环境感应配置        org.bluetooth.descriptor.es_configuration        0x290B        GSS
Environmental Sensing Measurement        环境感测        org.bluetooth.descriptor.es_measurement        0x290C        GSS
Environmental Sensing Trigger Setting        环境感应触发设定        org.bluetooth.descriptor.es_trigger_setting        0x290D        GSS
External Report Reference        外部报告参考        org.bluetooth.descriptor.external_report_reference        0x2907        GSS
Number of Digitals        数字个数        org.bluetooth.descriptor.number_of_digitals        0x2909        GSS
Report Reference        报告参考        org.bluetooth.descriptor.report_reference        0x2908        GSS
Server Characteristic Configuration        服务器特征配置        org.bluetooth.descriptor.gatt.server_characteristic_configuration        0x2903        GSS
Time Trigger Setting        时间触发设定        org.bluetooth.descriptor.time_trigger_setting        0x290E        GSS
Valid Range        有效范围        org.bluetooth.descriptor.valid_range        0x2906        GSS
Value Trigger Setting        数值触发设定        org.bluetooth.descriptor.value_trigger_setting        0x290A        GSS
GATT declarations(声明):
官方地址:https://www.bluetooth.com/specifications/gatt/declarations/
Characteristic Declaration        特征声明        org.bluetooth.attribute.gatt_.characteristic_declaration        0x2803        GSS
Include        包括        org.bluetooth.attribute.gatt_.include_declaration        0x2802        GSS
Primary Service        主要服务        org.bluetooth.attribute.gatt_.primary_service_declaration        0x2800        GSS
Secondary Service        次要服务        org.bluetooth.attribute.gatt_.secondary_service_declaration        0x2801        GSS
回复 支持 反对
GMT+8, 2026-3-2 13:56 , Processed in 0.107820 second(s), 37 queries .
