标题: LKS32 MCU 各系列资源对比 [打印本页]
作者: sunsili    时间: 2024-4-2 21:24
LKS32 MCU 各系列资源对比
LKS06x
LKS08x
LKS05x
LKS09x
LKS03x
LKS07x
Freq/MHz
96
96
96
192
48
96
Processor
32bit RISC
Cortex-M0
Cortex-M0
32bit RISC with FPU/DSP
32bit RISC
32bit RISC
DSP
DIV/SQRT peripherals1
Coprocessor2 with DIV/SQRT/CORDIC ability
SQRT/CORDIC peripherals
CORDIC peripherals
Coprocessor with DIV/SQRT/CORDIC ability
FMAC(Filter Accelerator)
DMA Channel/#
4
8
4
4
Debug
SWD
SWD
SWD
SWD/JTAG
SWD
SWD
Storage
Flash/kB
Main
32
64/32
32
256/128
32/16
128/64
NVR
0
1
1
18
2
ROM/kB
16
SRAM/kB
4
8
2.5
40
4
12
Analog
ADC
12bit×2
12bit×1
12bit×1
14bit×3
12bit×1
12bit×2
Sampling rate/Msps
3
3
3
2
1
3
DAC
12bit×1
12bit×1
12bit×1
12bit×1
8bit×1
12bit×2
Range/V
1/3.3
1.2/3/4.8
1.2/4.8
1.2/3.3
3.0
1.2/4.85
OPA/#
4
4
2/4
6
1/2
4
CMP/#
2
2
2
6
2
3
GPIO
#(max)
48
64
48
84
25
64
Pull-up
√(Some are available)
Pull-down
Open-drain
SWD as GPIO
RSTn as GPIO
Peripherals
UART
2
2
2
3
1
2+1(DSP emulated)
IIC
1
1
1
2
1
1
SPI
1
1
1
2
1
1
TIMER
16bit×4
16bit×2 + 32bit×2
16bit×2 + 32bit×2
16bit×3 + 32bit×2
16bit×1 + 32bit×1
16bit×2 + 32bit×2
QEP
2
2
4
2
CAN
√(CAN-FD)
SIF
Power Management
SLEEP/DEEPSLEEP
SLEEP/DEEPSLEEP
SLEEP/DEEPSLEEP
SLEEP/DEEPSLEEP/
Power Gating
SLEEP/DEEPSLEEP
SLEEP/DEEPSLEEP
WatchDog
1
1
1
2(IWDG+WWDG)
1
1
Clocks
HRC/MHz
4
4
4
12
4
8
LRC/kHz
32
32
64
64
64
64
XTAL/MHz
4
4/8
12/24
8
PLL/MHz
96
96
96
192
48
96
