标题: uboot 看emmc信息,读写emmc分区内容 [打印本页]
作者: 鸣涧    时间: 2022-5-3 00:08
                                                        在u-boot console中输入mmc,可以看到帮助信息:
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
   arguments (sizes in 512-byte blocks):
     [user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
     [gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
     [check|set|complete] - mode, complete set partitioning completed
   WARNING: Partitioning is a write-once setting once it is set to complete.
   Power cycling is required to initialize partitions after set to complete.
mmc setdsr <value> - set DSR register value
一:mmc的命令如下:
1:对mmc读操作
2:对mmc写操作
3:对mmc擦除操作
mmc erase blk# cnt
4:重新搜索mmc设备
mmc rescan
5:列出mmc的分区
mmc part - lists available partition oncurrent mmc device
6:查看当前的设备号,或者设置设备号及分区
mmc dev [dev] [part] - show or set currentmmc device [partition]
7:显示boot分区号
mmc bootpart [dev] [part] - show or setboot partition
8:列出当前的mmc设备
9:   打印一些当前mmc设备的信息
mmcinfo
二:mmc的命令详解
1:mmcinfo
输入:
mmcinfo(mmc与info之间有空格与没有空格的结果相同)
显示结果:
Manufacturer ID: 45
OEM: 100
Tran Speed: 25000000
Rd Block Len: 512
MMC version 4.0
Clock: 52000000
High Capacity: Yes
Capacity: 7944011776 Bytes
Bus Width: 8-bit DDR
Current Partition for boot: Boot partition 1
2:mmc list -lists available devices
输入:
mmc list
显示如下:
FSL_USDHC: 0
FSL_USDHC: 1
FSL_USDHC: 2
FSL_USDHC: 3
分析:boot中配置了四个mmc资源,SD卡是2,EMMC是3
3:mmc dev[dev] [part] - show or set current mmc device [partition]
输入:
mmc dev 3
显示如下:
mmc3(part 0) is current device
分析:表示当前处于EMMC设备的第0个分区。
注意:当你想从eMMC读取内容的时候,你需要先确定目标内容在哪一个分区。否则读出的内容是错误的。
从JEDEC标准里,可以看到eMMC在进行分区之前,包括User Data Area , RPMB,和两个启动分区。
输入:
mmc dev 3 1
显示如下:
mmc3(part 1) is current device
分析:设置当前处于EMMC设备的第1个分区
  # mmc dev 0 0
switch to partitions #0, OK
mmc0(part 0) is current device
分析:切换到mmc0设备的第0个分区
4:mmc  bootpart [dev] [part] - show or set boot partition
输入:
mmc bootpart
显示如下:
Device 3: boot partition 1 is for boot
分析:uboot处于第一个分区
5:mmc part -lists available partition on current mmc device
输入:
mmc part
显示如下:
Partition Map for UNKNOWN device 3  --  Partition Type: DOS
Partition     Start Sector     Num Sectors     Type
    1                16384           16384      83
    2                32768           16384      83
     3                49152         6397952       5 Extd
    4              6447104         9150464      83
    5                49153         3145727      83
    6              3194881         3145727      83
    7              6340609           16383      83
     8              6356993            8191      83
分析:显示当前EMMC的所有分区
6:mmc read   addr blk# cnt
这个命令的作用是读取mmc上的数据到内存上
参数:
addr: 读取到内存的地址值
blk:  读取block位置,这个位置是mmc相对于0地址的偏移量,是16进制,block单位是512字节
cnt:   读取的block个数,要读取到内存的数据大小,是16进制
例:
mmc    dev    3     0
mmc read   0x10800000 600 10
命令分析:表示从mmc上1536×512个字节开始处(1536是600的十进制),读取16×512个字节(16的16进制 表示为10)到内存0x10800000 处
显示结果:
MMC read: dev #3, block # 1536, count 16 ... 16 blocks read: OK
结果分析:
我们只能从结果看出来读取成功,但不能确定读取的内容是否正确,所以打印下内存的数据,看是否与mmc中的内容一致
输入:
md.b        0x10800000       100
命令分析:打印内存位置0x10800000的100个字节
显示结果:
10800000: b15ecb3c 6f62 746f 6564 616c 3d79 0033   ^.<.bootdelay=3.
10800010: 61626475 6172 6574 313d 3531 3032 0030   baudrate=115200.
10800020: 70696461 7264 313d 3239 312e 3836 312e   ipaddr=192.168.1
10800030: 312e3330 7300 7265 6576 6972 3d70 3931   .103.serverip=19
10800040: 2e323631 2e38 2e31 3031 0031 656e 6d74   2.168.1.101.netm
10800050: 73613d6b 3532 2e35 3532 2e35 3532 2e35   ask=255.255.255.
结果分析:
我在mmc位置1536×512的位置储存的是环境变量,与内存打印的一致,读取正确
7:mmc write addr blk# cnt
这个命令的作用是将内存上的数据写入mmc中
参数:
addr: 从内存读取的位置
blk:  写入到mmc中block位置,这个位置是mmc的0地址的偏移量,是16进制,block单位是512字节
cnt:   写入到mmc中block个数,要写入的数据大小,是16进制,
block单位是512字节
例:
mmc dev 3
mmc write     0x108000000     0       100
命令分析:表示从内存0x108000000的位置上读取256*512的数据(256是100的十进制)到mmc上0的位置处,这里就不举例验证了
mmc上0的位置处是分区表,我把内存上的乱数据写进去后,uboot检测不到分区了
8:mmc erase blk# cnt
参数:
blk:  擦除的mmc中block位置,这个位置是mmc的0地址的偏移量,是16进制,block单位是512字节
cnt:   擦除的mmc中block个数,是16进制,block单位是512字节
