标题: Oracle VM Virtualbox启动报cannot access the kernel driver的解决 [打印本页]
作者: 鸣涧_GC96O    时间: 2021-1-15 18:24
[问题描述]
手贱,动了网卡配置,把VM vitualbox服务给卸载,然后各种启动不了,重装安装错误依然,提示:
  1. Cannot access the kernel driver!
  2. Make sure the kernel module has been loaded successfully.
点确定,又提示:
  1. Failed to open a session for the virtual machine Masonux.
  2. Virtual machine 'Masonux' has terminated unexpectedly during startup.
  3. Details:
  4. Result Code:
  5. E_FAIL (0x80004005)
  6. Component:
  7. Machine
  8. Interface:
  9. IMachine {540dcfda-3df2-49c6-88fa-033a28c2ff85}
最后终于找到答案,陪你经历千辛万苦,解决问题的路上。
[解决方法]
操作步骤:
1、进入{VitualBox安装目录}\drivers\vboxdrv文件夹
2、找到vboxdrv.inf这个文件,鼠标右键点,然后选择安装。
3、启动虚拟机,一切OK了
OMG
