内置EQ音效调试
支持红外遥控
支持TWS自动配对
支持USB声卡\USB音箱
支持FM收音机
内置RISC-V 32Bits CPU + DSP
S-BE5607E PCBA实物图
| ID | Name | Designator | Footprint | Quantity | Manufacturer Part | Manufacturer | Supplier | Supplier Part |
1 | 1uF | C8,C12,C13,C10,C14,C15,C7,C4,C5,C6,C1,C2,C3,C9 | C0402 | 14 | CC0402KRX5R6BB105 | YAGEO(国巨) | ||
2 | 2.2Ω | R8,R7 | R0805 | 2 | 0603WAF220KT5E | UNI-ROYAL(厚声) | ||
4 | LK8002D | U2 | SOP-8_L5.1-W3.9-P1.27-LS6.0-BL | 1 | 8002D | LTKCHIP(联辉科) | C406249 | |
5 | 22uF | C11 | C1206 | 1 | GRM31CR61C226KE15L | muRata(村田) | C77088 | |
6 | 10kΩ | R9 | R0402 | 1 | 0402WGF1002TCE | UNI-ROYAL(厚声) | ||
7 | 33kΩ | R10 | R0402 | 1 | 0402WGF3302TCE | UNI-ROYAL(厚声) | ||
8 | GSPK2308P-8R0.5W | SPK1 | CONN-SMD_2P-P1.27_GH125-S02CCA-00 | 1 | GSPK2308P-8R0.5W | INGHAi(赢海) | ||
9 | Type-C | P3 | TypeC_16pin | 1 | ||||
10 | USB-A型母座 180度 短体 直边 | USB1 | USB-A-SMD_WT_C9900004571 | 1 | USB-A型母座 180度 短体 直边 | |||
| 11 | 47K | R12 | R0603 | 1 | ||||
12 | 150K | R13 | R0603 | 1 | ||||
13 | 470K | R14 | R0603 | 1 | ||||
14 | TF-N02-N | SD1 | TF-SMD_XKTF-N02-N | 1 | TF-N02-N | HanElectricity(瀚源) | ||
15 | EJ-2_PHONEJACK2 | P2,P1 | AUDIO-TH_EJ-2_PHONEJACK2 | 2 | EJ-2_PHONEJACK2 | |||
| 16 | 100R | R4,R5,R6,R1,R2,R3 | R0603 | 6 | ||||
17 | TS-1007S-26 | SW2,SW3,SW4,SW5,SW1 | SW-SMD_L6.1-W3.7-LS7.9 | 5 | TS-1007S-26 | XUNPU(讯普) | LCSC | |
| 18 | D-060306G1/SS2/G1 | LED1,LED2 | LED0603-RD | 2 | D-060306G1/SS2/G1 | ARKLED(方舟) | ||
19 | S-BE5607E | U1 | SOP-16_L9.9-W3.9-P1.27-LS6.0-BL | 1 | S-BE5607E | |||
| 20 | 12K | R11 | R0603 | 1 | ||||
21 | 贴片端子 | B1 | CONN-SMD_2P-P1.27_GH125-S02CCA-00 | 1 | SMD_2P-P1.27 | |||
| 22 | 220nH | L1 | L0603 | 1 | CS0603-R22J-S | chilisin(奇力新) | ||
23 | 26MHz | X1 | CRYSTAL-SMD_4P-L3.2-W2.5-BL_SIT8008BI | 1 | XL2EL89CMI-111YLC-26M | YXC(扬兴晶振) | ||
24 | TVS | D1 | SOD-523_L1.2-W0.8-LS1.6-BI | 1 | TVS | |||
| 25 | D_1N4007 | D2 | SMA_1N4007 | 1 | ||||
27 | 9pF/NC | C16,C17 | C0402 | 2 | CL05C090DB5NNNC |
