标题:
运行apt update 出错 Problem executing scripts APT::Update::Post-Invoke-Su...
[打印本页]
作者:
sunsili
时间:
2023-7-13 14:21
标题:
运行apt update 出错 Problem executing scripts APT::Update::Post-Invoke-Success
现象
运行apt update 出错
Aborted (core dumped)
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh > /dev/null; fi'
E: Sub-process returned an error code
解决方法
运行如下命令:
sudo apt purge libappstream3 -y
Powered by Discuz! X3.2
