标题: OpenWrt source repository downloads 各分支源码下载 [打印本页]
作者: sunsili 时间: 2023-7-1 16:52
OpenWrt source repository downloads OpenWrt 各分支源码下载
The recommended way of checking out the OpenWrt source code is cloning the Git repository using one of the following commands:
trunk (main development tree, now on GitHub)
下载OpenWrt 源代码的推荐方法是使用以下命令之一克隆 Git 存储库:- Main repository(主分支,现主要使用的最新更新的分支, 用此分支可以最新特性体验,版本号有16 18 20 21 22 23 ): ChangeLog
- git clone git://github.com/openwrt/openwrt.git
15.05 branch (Chaos Calmer)(一个分支名为Chaos Calmer发行版本,版本号:15.05)
- Main repository: ChangeLog
- git clone -b chaos_calmer git://github.com/openwrt/openwrt.git
14.07 branch (Barrier Breaker)(一个分支名为Barrier Breaker发行版本, 版本号:14.07)
- git clone -b barrier_breaker git://github.com/openwrt/openwrt.git
12.09 branch (Attitude Adjustment)(一个分支名为Attitude Adjustment发行版本, 版本号:12.09)
- Main repository: ChangeLoggit clone -b attitude_adjustment git://github.com/openwrt/openwrt.git
- Packages feed: ChangeLog (Due to legacy reasons, the packages feed are on git server which was used before migrating to GitHub)包源:更改日志(由于历史遗留原因,包源位于迁移到 GitHub 之前使用的 git 服务器上)
- git clone git://git.openwrt.org/12.09/packages.git
作者: sunsili 时间: 2023-7-6 16:38
更多版本下载:https://openwrt.org/downloads
