QCS610 | ||
CPU | Kryo 460: 64-bit Octa-cores, 2x Gold (2.2GHz) + 6x Silver (1.8GHz) | |
GPU | Adreno 612 @ up to 845MHz ; API Support: Vulkan® 1.1, OpenCL™, OpenGL® ES 3.2 | |
Audio Playback | Hi-Res/192kHz, Native 44.1kHz, audio on dedicated DSP | |
Compute DSP | Hexagon DSP with 2 Hexagon Vector eXtensions (HVX), 1.1Ghz | |
Sensor DSP | Hexagon DSP based | |
Memory | 2x 16-bit LPDDR4.x 1804MHz | |
PMIC | Qualcomm® PM6150 + Qualcomm® PM6150L | |
Display | Resolution | 2520x1080 60 fps + 1920x1200 60 fps (External) |
Interface | 1x4 lane DSI DPHY 1.2 support + DP over USB-C (external) | |
Camera | Performance | Image Signal Processor: Qualcomm Spectra™ 250L image signal processor, 14-bit, 24MP (2x ISP/16+16MP), 4K30 IQ improvement: MCTF, TNR, sHDR, EIS, LDC, Dewarp, Zoom |
Interface | CSI 4+4+4 lane (or 4+4+2+1), DPHY1.2, CPHY 1.0 | |
Video | Decode | 4K30 8-bit: H.265(HEVC)/VP9 |
Encode | 4K30 8-bit HEVC | |
Location | GPS/GLONASS, BeiDou, Galileo | |
Wired/Wireless Connectivity | Ethernet RGMII Integrated 1x1 802.11a/b/g/n/ac and Bluetooth 5.0 FM | |
Storage | eMMC 5.1, UFS 2.1 Gear3 1-lane, SD 3.0 | |
Peripherals | 1x USB3.1 Type-C with Display Port and USB 2.0 | |
Technology / Package | 11nm, 12x11.1x0.92mm non-PoP | |
QCS610 SOM | ||
Memory | 32Gb LPDDR4.x | |
64GB eMMC5.1 | ||
Wireless Connectivity | Integrated 1x1 802.11a/b/g/n/ac Bluetooth 5.0 | |
Display | Resolution | 2520x1080 60 fps |
Interface | 1x4 lane DSI DPHY 1.2 support | |
Camera | Performance | 24MP (2x ISP/16+16MP), 4K30 IQ improvement: TNR, sHDR, EIS, LDC |
SOM Size | 40 mm x 45 mm | |
No. | IO name | Port | Description |
1 | 802.11a/b/g/n/ac Bluetooth 5.0 | 1 | 1x1 antenna |
2 | RGMII | 1 | One RGMII interface with MDIO for Ethernet with AVB (1.8 V only for RGMII and MDIO) |
3 | SPI | 4 | SPI interface – 4 on GPIO and 2 on LPI for cameras, sensors, and so on; dedicated controller for each port |
4 | UART | 2 | UART interface 4 on GPIO – 3 on LPI island for sensors |
5 | I2C | 4+2 | >> I2C interface – 4(6) on GPIO and 1 on LPI for touch, sensors, and so on; dedicated controller for each port >> Two dedicated I2C interfaces for camera |
6 | SD | 1 | 4-bit SDC2 for SD Card 3.0 |
7 | USB3.0 | 1 | |
8 | USB2.0 | 1 | Option(Host) |
9 | CSI | 3 | 2 ports 4 lanes ; 1 port 2 lanes |
10 | DSI | 1 | 1 port 4 lanes |
11 | DMIC | 2 | |
12 | GPIOs | 20 | |
13 | I2S | 2 | 1 is for WCD9370 |
ecode 4K30 8-bit: H.265(HEVC)/VP9,Encode 4K30 8-bit HEVC;SOM Size :40 mm x 45 mm;===========================No. IO name Port Description1 .802.11a/b/g/n/ac and Bluetooth 5.0 1 1x1 antenna 2 .RGMII 1 One RGMII interface with MDIO for 3. SPI 4 SPI interface – 4 on GPIO and 2 on LPI for cameras, sensors, and so on; dedicated controller for each port4 .UART 2 UART interface 4 on GPIO – 3 on LPI island for sensors5 .I2C 4+2 >> I2C interface – 4(6) on GPIO and 1 on LPI for touch, sensors, and so on; dedicated controller for each port >> Two dedicated I2C interfaces for camera6 .SD 1 4-bit SDC2 for SD Card 3.07. USB3.0 1 8. USB2.0 1 Option(Host)9 .CSI 3 2 ports 4 lanes ; 1 port 2 lanes10. DSI 1 1 port 4 lanes11. DMIC 2 12. GPIOs 20 13. I2S 2 1 is for WCD9370| 欢迎光临 谷动谷力 (http://bbs.sunsili.com/) | Powered by Discuz! X3.2 |
