$ mkdir ~/bin $ PATH=~/bin PATH$ curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo $ chmod a+x ~/bin/repo |
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo build-essential \ chrpath socat libsdl1.2-dev xterm sed cvs subversion coreutils texi2html \ docbook-utils python-pysqlite2 help2man make gcc g++ desktop-file-utils \ libgl1-mesa-dev libglu1-mesa-dev mercurial autoconf automake groff curl lzop \ asciidoc |
$ git config --global user.name "your name" $ git config --global user.email your@example.com |
$ cd ~ $ mkdir imx-yocto-bsp $ cd imx-yocto-bsp $ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml $ repo sync |
$ DISTRO=fsl-imx-x11 MACHINE=imx6ulevk source fsl-setup-release.sh -b build-x11 $ cd ~/imx-yocto-bsp $ vim build-x11/conf/local.conf |
BB_NUMBER_THREADS = “12” PARALLEL_MAKE = “-j 1” //该参数不要改 |
$ bitbake fsl-image-validation-imx |
$ bitbake fsl-image-validation-imx -c populate_sdk |
$ bitbake -c compile linux-imx $ bitbake -c deploy linux-imx |
