标题: 【平头哥Sipeed LicheeRV 86开发板试用】系统镜像烧录运行体验 [打印本页]
作者: 鸣涧 时间: 2022-3-9 22:10
【平头哥Sipeed LicheeRV 86开发板试用】Tina Debian系统镜像烧录运行体验
Tina Licheepi RV86系统体验
系统镜像下载
百度云下载的:
提取码:wbef
烧录系统镜像
上述下载有工具PhoenixCard烧录系统镜像(tina_d1-nezha_uart0.img)到miniSD卡
打开烧录软件,选择启动卡(不知道哪里写的,我烧录量产是需要写NandFlahs才能启动,板子没有焊,所以启动不了,要迁启动卡)按顺序点击下图按键进行烧录对应镜像
运行Tina系统
烧录后,插入Sipeed LicheeRV 86开发板运行体验一下吧
- BusyBox v1.27.2 () built-in shell (ash)
- __ ___ _ __ _
- / |/ /__ _(_)_ __ / / (_)__ __ ____ __
- / /|_/ / _ `/ /\ \ / / /__/ / _ \/ // /\ \ /
- /_/ /_/\_,_/_//_\_\ /____/_/_//_/\_,_//_\_\
- Maix Linux (Neptune, 5C1C9C53)
复制代码 多么熟悉的Logo, 到这运行tina系统,完美结束了,下面体验一下Debian
Debian镜像体验
烧录LicheeRV_Debian_86_480p 为 480p的86盒板卡的debian镜像烧录完成后,插卡启动,稍等2分钟左右,屏幕上就会显示登录界面
输入用户名 sipeed,密码 licheepi,即可进入桌面 (使用USB HOST口外接键鼠输入,此操作相当不爽,我还是喜欢ssh)进入桌面后可以进行一些基础操作
连接Debian,默认是有线网络
无线网络开不起来,不知道 为什么,有知道的大神告诉一声:
- sipeed@sipeed:~$ ifconfig
- eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
- inet 192.168.0.74 netmask 255.255.255.0 broadcast 192.168.0.255
- inet6 fe80::476:eeff:fe10:2e4e prefixlen 64 scopeid 0x20<link>
- ether 06:76:ee:10:2e:4e txqueuelen 1000 (Ethernet)
- RX packets 1189 bytes 113529 (110.8 KiB)
- RX errors 0 dropped 0 overruns 0 frame 0
- TX packets 1159 bytes 120178 (117.3 KiB)
- TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
- device interrupt 62
- lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
- inet 127.0.0.1 netmask 255.0.0.0
- inet6 ::1 prefixlen 128 scopeid 0x10<host>
- loop txqueuelen 1000 (Local Loopback)
- RX packets 8 bytes 400 (400.0 B)
- TX packets 8 bytes 400 (400.0 B)
- sipeed@sipeed:~$ sudo ifconfig wlan0 up
- SIOCSIFFLAGS: Operation not possible due to RF-kill
可以使用apt安装程序,可惜没有RISV的源,愿以后会有吧
- sipeed@sipeed:~$ sudo apt install wget
- Reading package lists... Done
- Building dependency tree... Done
- Reading state information... Done
- Package wget is not available, but is referred to by another package.
- This may mean that the package is missing, has been obsoleted, or
- is only available from another source
- E: Package 'wget' has no installation candidate
接下来让我们尝试在Debian下跑一下Hello World:
编译运行:
- sipeed@sipeed:~$ gcc -o hello hello.c
- sipeed@sipeed:~$ ./hello
- Hello RISc-V Licheepi RV 86!!!!!!
- sipeed@sipeed:~$
本来想就这样开发的,不用PC交叉编译的,但大项目多线程编译不过, 有知道 大神告诉一声谢谢
总结
Tina烧录系统镜像 运行挺快的,Debina体验不爽, 这个MCU性能就不能运行Debian了,又不能apt,可能RISC-V是新生事物吧,没有源,希望后面会有RISC-V的源
下回检验预告
下回我们点亮LED灯吧
