     | 【openwrt】编译OpenWRT 15.05(Chaos Calmer CC)出错m4-1.4.17 和findutils-4.4.2库 freadahead.c文件错误解决方法 编译m4-1.4.17库时出现关于 freadahead.c中编译错误 现象 出错提示如下 : freadahead.c: In function 'freadahead': freadahead.c:91:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib." 91 | #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib." ......... make[1]: *** [tools/Makefile:121: /home/fan/openwrt_CC_mt76xx_zhuotk_source/staging_dir/target-mipsel_mips32_uClibc-0.9.33.2/stamp/.tools_install_yynyynynynyyyyyyyyynyyyyyyyyynyyyyynnyyynnyynnnyy] Error 2 make[1]: Leaving directory '/home/fan/openwrt_CC_mt76xx_zhuotk_source' make: *** [/home/fan/openwrt_CC_mt76xx_zhuotk_source/include/toplevel.mk:183: world] Error 2 解决方法 进入文件夹 /buildroot/output/build/host-m4-1.4.17 cd build_dir/host/m4-1.4.17/ 输入命令: sed -i 's/IO_ftrylockfile/IO_EOF_SEEN/' lib/*.c echo "#define _IO_IN_BACKUP 0x100" >> lib/stdio-impl.h #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib 编译findutils-4.4.2时 同样有freadahead.c文件错误 现象 出错提示如下: freadahead.c: In function 'freadahead': freadahead.c:64:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread on your system, then report this to bug-gnulib." #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread on your ^ make[8]: *** [Makefile:890: freadahead.o] Error 1 make[8]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source/build_dir/host/findutils-4.4.2/gnulib/lib' make[7]: *** [Makefile:696: all] Error 2 make[7]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source/build_dir/host/findutils-4.4.2/gnulib/lib' make[6]: *** [Makefile:606: all-recursive] Error 1 make[6]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source/build_dir/host/findutils-4.4.2/gnulib' make[5]: *** [Makefile:643: all-recursive] Error 1 make[5]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source/build_dir/host/findutils-4.4.2' make[4]: *** [Makefile:582: all] Error 2 make[4]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source/build_dir/host/findutils-4.4.2' make[3]: *** [Makefile:21: /home/fan/openwrt_CC_mt76xx_omj_source/build_dir/host/findutils-4.4.2/.built] Error 2 make[3]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source/tools/findutils' make[2]: *** [tools/Makefile:123: tools/findutils/compile] Error 2 make[2]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source' make[1]: *** [tools/Makefile:121: /home/fan/openwrt_CC_mt76xx_omj_source/staging_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/stamp/.tools_install_yynyynynynyyyyyyyyynyyyyyyyyynyyyyynnyyynnyynnnyy] Error 2 make[1]: Leaving directory '/home/fan/openwrt_CC_mt76xx_omj_source' make: *** [/home/fan/openwrt_CC_mt76xx_omj_source/include/toplevel.mk:183: world] Error 2 解决方法 cd build_dir/host/findutils-4.4.2 sed -i 's/IO_ftrylockfile/IO_EOF_SEEN/' lib/*.c echo "#define _IO_IN_BACKUP 0x100" >> lib/stdio-impl.h sed -i 's/IO_ftrylockfile/IO_EOF_SEEN/' gnulib/lib/*.c echo "#define _IO_IN_BACKUP 0x100" >> gnulib/lib/stdio-impl.h echo "#define _IO_ferror_unlocked" >> gnulib/lib/stdio-impl.h sed -i '/unistd/a #include <sys/sysmacros.h>' gnulib/lib/mountlist.c 问题依然 findutils-4.6.0替换findutils-4.4.2 切换到dl目录 cd dl 下载findutils-4.6.0 wget https://mirrors.aliyun.com/gnu/findutils/findutils-4.6.0.tar.gz 获取findutils-4.6.0.tar.gz的md5码 md5sum findutils-4.6.0.tar.gz 9936aa8009438ce185bea2694a997fc1 findutils-4.6.0.tar.gz 修改Makefile cd ../tools/findutils/ vim Makefile # # Copyright (C) 2006-2013 OpenWrt.org ... # Vsersion PKG_VERSION:=4.6.0 ..... # PKG_MD5 PKG_MD5SUM:=9936aa8009438ce185bea2694a997fc1 ..... 删除patch 21-Fix-time_t-vs-long-int-mismatches.patch(此文件在4.4.x需要, 4.6.x已经修复了此bug所以不需要了) rm -f patches/21-Fix-time_t-vs-long-int-mismatches.patch 切换目录 cd ../../build_dir/host/findutils-4.6.0 维修源码, 运行以下命令: sed -i 's/IO_ftrylockfile/IO_EOF_SEEN/' lib/*.c echo "#define _IO_IN_BACKUP 0x100" >> lib/stdio-impl.h sed -i 's/IO_ftrylockfile/IO_EOF_SEEN/' gl/lib/*.c echo "#define _IO_IN_BACKUP 0x100" >> gl/lib/stdio-impl.h sed -i '/unistd/a #include <sys/sysmacros.h>' gl/lib/mountlist.c 重新编译,此问题消除 |
( 粤ICP备14060730号 )  |Sitemap
GMT+8, 2025-10-24 18:20 , Processed in 0.081817 second(s), 34 queries .
