【linux】OPENWRT串口通信stty安装使用
2022-7-5 23:34| 发布者: 鸣涧| 查看: 428| 评论: 0|原作者: 鸣涧
摘要: 【linux】OPENWRT串口通信stty安装使用 概述:本文讲述如何在【linux】OPENWRT环境下安装使用串口通信工具stty stty安装--在线安装 在线安装 前题先连接网络 更新opkg Openwrt是基于opkg包管理,安装前先更新opkg ...
概述
本文讲述如何在【linux】OPENWRT环境下安装使用stty串口通信工具对串口参数设置,并使用cat  echo 命令进行串口通信。
stty安装--在线安装
在线安装 前题先连接网络
更新opkg
Openwrt是基于opkg包管理,安装前先更新opkg,注意要连接网络
root@SunLink:~# opkg update
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/pack        ages/base/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/pack        ages/base/Packages.sig.
Signature check passed
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/pack        ages/telephony/Packages.sig.
Signature check passed.
stty安装
执行命令:
  1. opkg install coreutils-stty
root@SunLink:~# opkg install coreutils-stty
Installing coreutils-stty (8.23-1) to root...
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/pack        ages/packages/coreutils-stty_8.23-1_ramips_24kec.ipk.
Installing coreutils (8.23-1) to root...
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/pack        ages/packages/coreutils_8.23-1_ramips_24kec.ipk.
Configuring coreutils.
Configuring coreutils-stty.
stt查看帮助
不会新命令都执行一下加--help参数就没错
root@SunLink:~# stty --help
Usage: stty [-F DEVICE | --file=DEVICE] [SETTING]...
or:  stty [-F DEVICE | --file=DEVICE] [-a|--all]
or:  stty [-F DEVICE | --file=DEVICE] [-g|--save]
Print or change terminal characteristics.
Mandatory arguments to long options are mandatory for short options too.
-a, --all          print all current settings in human-readable form
-g, --save         print all current settings in a stty-readable form
-F, --file=DEVICE  open and use the specified DEVICE instead of stdin
--help     display this help and exit
--version  output version information and exit
Optional - before SETTING indicates negation.  An * marks non-POSIX
settings.  The underlying system defines which settings are available.
Special characters:
  • dsusp CHAR    CHAR will send a terminal stop signal once input flushed
eof CHAR      CHAR will send an end of file (terminate the input)
eol CHAR      CHAR will end the line
  • eol2 CHAR     alternate CHAR for ending the line
erase CHAR    CHAR will erase the last character typed
intr CHAR     CHAR will send an interrupt signal
kill CHAR     CHAR will erase the current line
  • lnext CHAR    CHAR will enter the next character quoted
quit CHAR     CHAR will send a quit signal
  • rprnt CHAR    CHAR will redraw the current line
start CHAR    CHAR will restart the output after stopping it
stop CHAR     CHAR will stop the output
  • swtch CHAR    CHAR will switch to a different shell layer
  • werase CHAR   CHAR will erase the last word typed
Special settings:
N             set the input and output speeds to N bauds
  • cols N        tell the kernel that the terminal has N columns
  • columns N     same as cols N
ispeed N      set the input speed to N
  • line N        use line discipline N
min N         with -icanon, set N characters minimum for a completed read
ospeed N      set the output speed to N
  • rows N        tell the kernel that the terminal has N rows
  • size          print the number of rows and columns according to the kernel
speed         print the terminal speed
time N        with -icanon, set read timeout of N tenths of a second
Control settings:
[-]clocal     disable modem control signals
[-]cread      allow input to be received
  • [-]crtscts    enable RTS/CTS handshaking
  • [-]cdtrdsr    enable DTR/DSR handshaking
csN           set character size to N bits, N in [5..8]
[-]cstopb     use two stop bits per character (one with '-')
[-]hup        send a hangup signal when the last process closes the tty
[-]hupcl      same as [-]hup
[-]parenb     generate parity bit in output and expect parity bit in input
[-]parodd     set odd parity (or even parity with '-')
  • [-]cmspar     use "stick" (mark/space) parity
Input settings:
[-]brkint     breaks cause an interrupt signal
[-]icrnl      translate carriage return to newline
[-]ignbrk     ignore break characters
[-]igncr      ignore carriage return
[-]ignpar     ignore characters with parity errors
  • [-]imaxbel    beep and do not flush a full input buffer on a character
[-]inlcr      translate newline to carriage return
[-]inpck      enable input parity checking
[-]istrip     clear high (8th) bit of input characters
  • [-]iutf8      assume input characters are UTF-8 encoded
  • [-]iuclc      translate uppercase characters to lowercase
  • [-]ixany      let any character restart output, not only start character
[-]ixoff      enable sending of start/stop characters
[-]ixon       enable XON/XOFF flow control
[-]parmrk     mark parity errors (with a 255-0-character sequence)
[-]tandem     same as [-]ixoff
Output settings:
  • bsN           backspace delay style, N in [0..1]
  • crN           carriage return delay style, N in [0..3]
  • ffN           form feed delay style, N in [0..1]
  • nlN           newline delay style, N in [0..1]
  • [-]ocrnl      translate carriage return to newline
  • [-]ofdel      use delete characters for fill instead of NUL characters
  • [-]ofill      use fill (padding) characters instead of timing for delays
  • [-]olcuc      translate lowercase characters to uppercase
  • [-]onlcr      translate newline to carriage return-newline
  • [-]onlret     newline performs a carriage return
  • [-]onocr      do not print carriage returns in the first column
[-]opost      postprocess output
  • tabN          horizontal tab delay style, N in [0..3]
  • tabs          same as tab0
  • -tabs         same as tab3
  • vtN           vertical tab delay style, N in [0..1]
Local settings:
[-]crterase   echo erase characters as backspace-space-backspace
  • crtkill       kill all line by obeying the echoprt and echoe settings
  • -crtkill      kill all line by obeying the echoctl and echok settings
  • [-]ctlecho    echo control characters in hat notation ('^c')
[-]echo       echo input characters
  • [-]echoctl    same as [-]ctlecho
[-]echoe      same as [-]crterase
[-]echok      echo a newline after a kill character
  • [-]echoke     same as [-]crtkill
[-]echonl     echo newline even if not echoing other characters
  • [-]echoprt    echo erased characters backward, between '' and '/'
[-]icanon     enable erase, kill, werase, and rprnt special characters
[-]iexten     enable non-POSIX special characters
[-]isig       enable interrupt, quit, and suspend special characters
[-]noflsh     disable flushing after interrupt and quit special characters
  • [-]prterase   same as [-]echoprt
  • [-]tostop     stop background jobs that try to write to the terminal
  • [-]xcase      with icanon, escape with '' for uppercase characters
Combination settings:
  • [-]LCASE      same as [-]lcase
cbreak        same as -icanon
-cbreak       same as icanon
cooked        same as brkint ignpar istrip icrnl ixon opost isig
icanon, eof and eol characters to their default values
-cooked       same as raw
crt           same as echoe echoctl echoke
dec           same as echoe echoctl echoke -ixany intr ^c erase 0177
kill ^u
  • [-]decctlq    same as [-]ixany
ek            erase and kill characters to their default values
evenp         same as parenb -parodd cs7
-evenp        same as -parenb cs8
  • [-]lcase      same as xcase iuclc olcuc
litout        same as -parenb -istrip -opost cs8
-litout       same as parenb istrip opost cs7
nl            same as -icrnl -onlcr
-nl           same as icrnl -inlcr -igncr onlcr -ocrnl -onlret
oddp          same as parenb parodd cs7
-oddp         same as -parenb cs8
[-]parity     same as [-]evenp
pass8         same as -parenb -istrip cs8
-pass8        same as parenb istrip cs7
raw           same as -ignbrk -brkint -ignpar -parmrk -inpck -istrip
-inlcr -igncr -icrnl  -ixon  -ixoff  -iuclc  -ixany
-imaxbel -opost -isig -icanon -xcase min 1 time 0
-raw          same as cooked
sane          same as cread -ignbrk brkint -inlcr -igncr icrnl -iutf8
-ixoff -iuclc -ixany imaxbel opost -olcuc -ocrnl onlcr
-onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
isig icanon iexten echo echoe echok -echonl -noflsh
-xcase -tostop -echoprt echoctl echoke, all special
Handle the tty line connected to standard input.  Without arguments,
prints baud rate, line discipline, and deviations from stty sane.  In
settings, CHAR is taken literally, or coded as in ^c, 0x37, 0177 or
127; special values ^- or undef used to disable special characters.
GNU coreutils online help: http://www.gnu.org/software/coreutils/
Report stty translation bugs to http://translationproject.org/team/
For complete documentation, run: info coreutils 'stty invocation'
stty应用举例
设置串口波特率
老规矩串口使用前先配置波特率
root@SunLink:~# stty -F /dev/ttyS2 raw speed 115200
115200
查看串口配置
speed 115200 baud; line = 0;
intr = ; quit = ; erase = ; kill = ; eof = ; susp = ;
rprnt = ; werase = ; lnext = ; flush = ; min = 1; time = 0;
-brkint -icrnl -imaxbel
-opost
-isig -icanon -iexten -echo
Shell命令读串口(接收数据)命令
cat /dev/ttyS1 & #后台运行
Shell命令写串口(发送数据)命令
echo -e "ttyS2 Sending....." > /dev/ttyS1
GMT+8, 2025-10-24 18:20 , Processed in 0.085648 second(s), 35 queries .
