【平头哥Sipeed LicheeRV 86开发板试用】opkg命令安装ipk软件包
2022-4-7 23:57| 发布者: 鸣涧| 查看: 424| 评论: 1|原作者: 鸣涧
摘要: 【平头哥Sipeed LicheeRV 86开发板试用】opkg命令安装ipk软件包 近日sipeed网站上看到, licheepi在ipk站了链接如下: http://opkg.gloomyghost.com/snapshots/ 有以下内容: base/ - 应用(库) kernel/ - . ...
链接如下:
有以下内容:
base/
    -    应用(库)
kernel/
    -    内核组件+驱动
安装tplayerdemo体验过程
下面是我的安装tplayerdemo体验过程
获取tplayerdemo的软件包ipk
在base里找tplayerdemo_1-1_sunxi,右键tplayerdemo_1-1_sunxi复制链接
  1. http://opkg.gloomyghost.com/snapshots/base/tplayerdemo_1-1_sunxi.ipk
下载ipk包
  1. root@MaixLinux:/mnt/UDISK# wget http://opkg.gloomyghost.com/snapshots/base/tplayerdemo_1-1_sunxi.ipk
  2. Connecting to opkg.gloomyghost.com (104.21.52.186:80)
  3. tplayerdemo_1-1_sunx 100% |*************************************************************************************
查看下载结果
  1. root@MaixLinux:/mnt/UDISK# ls
  2. 1.txt                       big_buck_bunny.mp4          jueju.mp4                   ql.mp4
  3. WhenYouSayNothingAtAll.mp4  jju.mp4                     qianliang.mp4               tplayerdemo_1-1_sunxi.ipk
安装tplayerdemo_1-1_sunxi.ipk软件包
  1. root@MaixLinux:/mnt/UDISK# opkg install tplayerdemo_1-1_sunxi.ipk
  2. Installing tplayerdemo (1-1) to root...
  3. Collected errors:
  4. * make_directory: Cannot create directory `//usr/lib/opkg': No space left on device.
  5. * make_directory: Cannot create directory `//usr/lib/opkg': No space left on device.
  6. * verify_pkg_installable: Only have 0kb available on filesystem /overlay, pkg tplayerdemo needs 10
  7. * opkg_install_cmd: Cannot install package tplayerdemo.
出错解决
提示root根分区大小不够了, df查看
  1. root@MaixLinux:/mnt/UDISK# df
  2. Filesystem           1K-blocks      Used Available Use% Mounted on
  3. /dev/root                99884     97836         0 100% /
  4. devtmpfs                247740         0    247740   0% /dev
  5. tmpfs                   251932        40    251892   0% /tmp
  6. /dev/mmcblk0p1            8151       677      7474   8% /mnt/SDCARD
  7. /dev/by-name/UDISK    21802544    187504  21615040   1% /mnt/UDISK
扩容SD卡及root分区
参考:
  【平头哥Sipeed LicheeRV 86开发板试用】扩展外部sd卡存 ...
【平头哥Sipeed LicheeRV 86开发板试用】SD卡中Linux系 ..
root分区扩容后, 查看分区情况
  3. /dev/root              8228024     98068   7694144   1% /
再次安装tplayerdemo_1-1_sunxi.ipk
  4. * satisfy_dependencies_for: Cannot satisfy the following dependencies for tplayerdemo:
  5. *      libc *  libssp *        librt *         libpthread *    libcedarx *     libstdcpp *
  6. * opkg_install_cmd: Cannot install package tplayerdemo.
还是出错, 提示少了些依赖库
安装依赖库
  1. root@MaixLinux:/mnt/UDISK# wget http://opkg.gloomyghost.com/snapshots/base/libc_-1_sunxi.ipk
  3. libc_-1_sunxi.ipk    100% |***************************************************************|  1175k  0:00:00 ETA
  4. root@MaixLinux:/mnt/UDISK# opkg install libc_-1_sunxi.ipk
  5. Installing libc (-1) to root...
  6. Collected errors:
  7. * satisfy_dependencies_for: Cannot satisfy the following dependencies for libc:
  8. *      libgcc *
  9. * opkg_install_cmd: Cannot install package libc.
  10. root@MaixLinux:/mnt/UDISK# wget http://opkg.gloomyghost.com/snapshots/base/libgcc_-1_sunxi.ipk
  11. Connecting to opkg.gloomyghost.com (172.67.202.218:80)
  12. libgcc_-1_sunxi.ipk  100% |***************************************************************| 41318   0:00:00 ETA
  13. root@MaixLinux:/mnt/UDISK# opkg install libgcc_-1_sunxi.ipk
  14. Installing libgcc (-1) to root...
  15. Configuring libgcc.
  16. ...............
  17. root@MaixLinux:/mnt/UDISK# opkg install libcedarx_2.8-1_sunxi.ipk
  18. Installing libcedarx (2.8-1) to root...
  19. Configuring libcedarx.
  20. root@MaixLinux:/mnt/UDISK#
中间过程太多,不一一写,操作方法,都一样的:
  • 获取tplayerdemo的软件包ipk链接,
  • wget下载软件包ipk
  • 安装软件包ipk
所有依赖库安装好后, 再次安装tplayerdemo_1-1_sunxi.ipk
  3. Configuring tplayerdemo.
出现上述提示信息, 恭喜你,
tplayerdemo 安装成功了
sunsili 2024-4-17 11:33
安装软件包错误提示,目标文件系统 /overlay 上没有足够的可用空间来完成这个操作。这通常发生在嵌入式系统或者空间受限的环境中,系统分区已满。
解决方法:
清理空间:删除不必要的文件或者应用,以释放足够的空间。可以使用 df -h 命令查看文件系统的使用情况,使用 du -sh * 命令查找可以清理的大文件或目录。
扩大分区:如果是虚拟环境或者有额外存储空间,可以考虑调整分区大小,或者添加额外的存储设备。
使用外部存储:如果可能,可以配置系统使用外部存储设备,比如USB驱动器或SD卡。
优化分区:如果是ext4或其他类型的文件系统,可以考虑使用工具如 e2fsck 来检查和优化文件系统。
确保在进行任何更改之前备份重要数据,以防出现数据丢失的情况。
GMT+8, 2025-10-24 18:20 , Processed in 0.081140 second(s), 35 queries .
