| 8051 结构提供给用户3 个不同的存储空间,程序存储器ROM,数据存储器RAM(内部RAM和外部RAM)。 随便打开一个8051MCU的datasheet, 现拿N76E003例说: ![]() Keil C51通过以下的关键字定义了不同的存储类型,从而确保用户能够访问到51架构的全部存储空间。 code:访问程序存储器ROM,即我们常说的代码段,用来存放可执行代码,空间可达64K(0x0000~0xffff),该存储空间的代码段是只读的。 定义大量常量数据时可以用 code, 不加在修饰的话RAM里,一般编译不通过,例如: code unsigned char HS6200_Calibration_Data[41] = { HS6200_BANK0_CONFIG, 0x03, HS6200_BANK0_RF_CH, 0x32, HS6200_BANK0_RF_SETUP, 0x40, }; code unsigned char HS6200_Calibration_DCtrl[4] = {1,1,1}; code unsigned char HS6200_Calibration_Analog[31] = { HS6200_BANK1_PLL_CTL0, 0x40,0x01,0x10,0xE5, HS6200_BANK1_CAL_CTL, 0x20,0x08,0x50,0x40,0x50, HS6200_BANK1_IF_FREQ, 0x00,0x00,0x1F, HS6200_BANK1_FDEV, 0x20, HS6200_BANK1_DAC_CAL_HI, 0x7F, HS6200_BANK1_RF_IVGEN, 0x1F,0x64,0x00,0x81, }; code unsigned char HS6200_Calibration_ACtrl[8] = {4,5,3,1,1,4}; /*config infor*/ code unsigned char HS6200_Analog_Data[46]= { HS6200_BANK1_PLL_CTL0, 0x40,0x01,0x30,0xE1, HS6200_BANK1_PLL_CTL1, 0x00,0x42,0x10,0x01, HS6200_BANK1_CAL_CTL, 0x29,0x89,0x75,0x28,0x50, HS6200_BANK1_RX_CTRL, 0x52,0xC2,0x09,0xAC, HS6200_BANK1_FAGC_CTRL_1, 0x80,0x14,0x08,0x29, HS6200_BANK1_RF_IVGEN, 0x1F,0x64,0x00,0x01 }; unsigned char HS6200_Analog_Ctrl[10]={4,4,5,4,4,4}; code unsigned char HS6200_Init_Data[40]= { HS6200_BANK0_CONFIG, 0x0e, HS6200_BANK0_RX_PW_P0, 0x0A, //*根据需要配置*// HS6200_BANK0_DYNPD, 0x3F, HS6200_BANK0_FEATURE, 0x07, HS6200_BANK0_SETUP_VALUE, 0x40,0x5A,0x80,0x06,0x00, HS6200_BANK0_PRE_GURD, 0x77, HS6200_BANK0_EN_AA, 0x3F, HS6200_BANK0_EN_RXADDR, 0x3F, HS6200_BANK0_SETUP_AW, 0x03, HS6200_BANK0_SETUP_RETR, 0x0F, //*根据需要配置*// HS6200_BANK0_RF_CH, 0x46, HS6200_BANK0_RF_SETUP, 0x47, HS6200_BANK0_RX_ADDR_P0, 0x55,0x42,0x9C,0x8F,0xC9, HS6200_BANK0_TX_ADDR, 0x55,0x42,0x9C,0x8F,0xC9, }; code unsigned char HS6200_Init_Ctrl[14]={1,1,1,1,5,1,1,1,1,1,1,1,5,5}; 刚开始没加code, 编译超RAM空间了。 data:访问可直接寻址的片内存储器,即内部RAM,即我们常说的DATA区或数据段,在整个RAM块中只占前128 字节(0x00~0x7f),因为它采用直接寻址方式,对变量最高速的访问最快,通常我们把使用比较频繁的变量或局部变量存储在DATA 段中,但是次数必须节省,因为它的空间毕竟有限。 代码定义的数据(数组)变量一般不加修饰,就是在RAM(DATA)里。 DATA数据段中分为两个子段,第一个子段包含四组寄存器组,每组寄存器组包含八个寄存器,共32 个寄存器;另外一个子段叫做位寻址段BDATA, 大小16 个字节,共128 位,每一位都可单独寻址。 例: sbit LED= P1^2 bdata:访问位寻址的片内存储器,即访问内部RAM,在其中从20H开始的16字节(0x20~0x2f)。 xdata:访问外部数据存储器,即外部RAM,大小64K(0x0000~0xffff),16 位地址寻,称作外部数 据区简称XDATA 区,访问XDATA 须采用间接寻址。访问速度尽次于RAM(DATA) 例 xdata uint32_t arry[16]; 一般可设置编译自己转大数据到XDATA(XRAM) ![]() idata:访问间接寻址的内部RAM ,256个字节(0x00~0xff),在8051 系列的一些单片机如8052 有附加的128 字节的内部RAM,固定指前面0x00-0xff的256个字节的片内RAM,其中前128字节和data的128字节完全相同,只是因为访问的方式不同。 pdata:访问当前页面内的外部RAM中的XDATA,每一页256字节,按页访问。PDATA 段只有256 个字节,而XDATA段可达65536 个字节(64K嘛),对PDATA 和XDATA 的操作是相似的,但是对PDATA 段寻址比对XDATA 段寻址要快,因为对PDATA 段寻址只需要装入8 位地址,而对XDATA 段寻址需装入16 位地址,所以尽量把外部数据存储在PDATA 段中。 说明不到清楚的地方,请大家指正。欢迎在评论区讨论。 |
GMT+8, 2025-10-24 18:20 , Processed in 0.162820 second(s), 35 queries .
